[FiiO UTWS5 2025/UTWS5] True Wireless Bluetooth Amplifier Is Officially Released!
Jan 31, 2025 at 6:09 AM Post #3,091 of 3,137
What are you even talking about? Any additional function should be switchable. That is, next to the transparency regulator, check the box "Automatically turn on when paused". Just turn it off (when it appears in the future), if you don't need it, and then you won't have to talk about it much.
As I’ve said, I’m all for it. :) Go FiiO, we believe in you.
I just told you my personal priorities; I don’t understand why it’s hard to grasp. Ambient mode is wonderful — I use it every time I go somewhere.
Jan 31, 2025 at 7:45 AM Post #3,092 of 3,137
Just buy Shure TW2 and be done with it. It has everything you are looking for for just a bit more money but has 2 year US based warranty, no sending to China. I use with 2 pin with adapters. The environment mode works perfectly and app is much better.
I have the Shure TW2 but some of my IEM's need more power. Also, with the 2 pin adapter it's a bit long. If the Shure TW2 had a bit more power or a 2 pin version, they would be perfect and I wouldn't look elsewhere.
From the support:
"If you would like to use the firmware 0.63 with ambient sound function,
here is the download link:
UTWS5 2025 0.63 firmware with ambient function:
https://fiio-firmware.fiio.net/UTWS5 2025/UTWS5_2025_bt_dfu_v0.63_ambient.bin
FIIO 3.29 download link:
https://fiio-firmware.fiio.net/FiiOControl/FiiOControl-v3.29.apk
Note: You could use the FiiO Control APP 3.29 version for ambient sound adjustment and triple click the button in right earhook to enable/disable ambient sound function."
Thank you for your help!
Unfortunately this does not work for me. The firmware upgrades, but that version of FIIO Control will not install as not compatible with my Pixel 9 pro running stock Android 15. Any suggestions?
Feb 22, 2025 at 4:00 AM Post #3,094 of 3,137
Just use the latest version. Automatic volume mode works fine for me.
Feb 24, 2025 at 2:07 AM Post #3,095 of 3,137
Searched but did not find recently asked by anyone.
UTWS5 2025 is missing Battery Protection option in application while UTWS5 Gen1 still has it.
Have FiiO removed this option for 2025 model?
Dear friend,
Hi, since the earbuds of the UTWS5 2025 is using wireless charging, the battery protection function could not be added.
Best regards
Mar 2, 2025 at 11:36 AM Post #3,096 of 3,137
Dear friend,
Best regards
What is the expected life of the batteries? I presume its now even shorter with out 'battery protection' and wireless charging resistance will heat them up more causing even more rapid degradation.
Please consider making the batteries replaceable so the device isn't junk after 100-300 cycles
Apr 7, 2025 at 3:25 AM Post #3,099 of 3,137
The FiiO UTWS5 sounds like a major leap forward for true wireless audio! The introduction of the AK4332 DAC is a game-changer for improving sound quality, especially with its low power consumption and enhanced performance
Apr 7, 2025 at 6:22 AM Post #3,100 of 3,137
I was thinking about getting the UTWS5 2025 for my Noble K10 CIEMs but I'm not sure if they will fit in the case or not. Would someone be able to measure the inside space or confirm if my CIEMs will fit? For reference they are 25mm deep, 32mm wide and 24mm tall.
Apr 8, 2025 at 2:17 PM Post #3,101 of 3,137
It can fit Moondrop Blessing 2. Which are pretty big IEMs
Apr 11, 2025 at 5:36 PM Post #3,105 of 3,137
Hi. Can the filter type (peak, lowshelf, highshelf) be selected in FiiO app for UTWS5 2025 when setting PEQ? I have the older UTWS5 and filter type can't be selected and I was wondering if this was fixed with the new UTWS5 version. Thanks.
