[FiiO UTWS5 2025/UTWS5] True Wireless Bluetooth Amplifier Is Officially Released!
Aug 22, 2022 at 1:36 AM Post #1,576 of 3,150
what sourse do you use with what codec? Indigo are amazing and nice to see people using it not with super expensive daps.
eppfun AK3046D Bluetooth 5.2 Qualcomm aptX-Adaptive HD Transmitter with 3.5mm AUX/RCA/COAXIAL/SPDIF Optical, SBC / aptX /aptX-ll Low Latency Dual Connection Audio Adapter for TV PC (Black) https://a.co/d/3olcMgF
Using this bluetooth transmitter connected to my pc using AptX adaptive.
Aug 22, 2022 at 1:50 AM Post #1,577 of 3,150
nice source with aptx adaptive, thanks. Haven't seen this thing. For use with pc it should be really really nice. What do you think about aptx adaptive, does it meets your needs with utws5 for such high end iem?
Aug 22, 2022 at 1:50 AM Post #1,578 of 3,150
Aug 22, 2022 at 1:56 AM Post #1,579 of 3,150
I listen to youtube video a lot, some flac files and no complain so far. AptX adaptive is kinda overkill for youtube compression anyway. I also use AptX adaptive to play Dota2 and it really almost no noticeable delay unlike AptX HD.
Sep 2, 2022 at 1:59 PM Post #1,581 of 3,150
@FiiO , when are we going to receive the new firmware?
Sep 5, 2022 at 4:33 PM Post #1,583 of 3,150
Hi guys, any experience with lhdc and phones that are newer than the ones on the LHDC supporting list for utws5?
I want to buy some qualcom 8+ gen1 chipset phone to have also aptx lossless.
Utws5 quality on normal aptx connection is good but not quite satisfactory to my ears.
Sep 6, 2022 at 10:36 AM Post #1,584 of 3,150
I wonder.. how many people do have the problem with the UTWS5 discharging itself from time to time (it's always one of the hooks) in the box?
And then there's also the problem of one of the hooks not starting to charge when you put the hooks into the box - and then needing to remove the said hook out of the box and putting it back in a few times to get it to start to charge?
These are the two inherent native problems with the UTWS5. I got my replacement unit and still these problems persist. My version is the old 3 pin version. Got a headache talking to the seller here in Germany. They want to make it seem that i'm the problem or the USB char´ging device would be the problem.
I asked to get the revision with the 2 pins but no response by them regarding this.
Sep 6, 2022 at 12:53 PM Post #1,585 of 3,150
I also have this problem and most often on the left hook. I am also with three pin hooks.
Sep 6, 2022 at 3:54 PM Post #1,586 of 3,150
Is there any way for M11 Pro to connect to UTWS5 with LHDC? The Fiio Music app has a toggle to turn LHDC on, but there is no feedback showing that it is actually working. I doubt it actually is.
Sep 7, 2022 at 4:00 AM Post #1,588 of 3,150
I’m using my old utws3 case to charge my utws5 buds. The battery isn’t great on the case but I don’t have much of a choice
Sep 7, 2022 at 9:17 PM Post #1,589 of 3,150
Dear friend,
Please try to clean the charging pins follow the instruction in this FAQ to check again: https://www.fiio.com/newsinfo/472905.html
Best regards
Sep 7, 2022 at 9:21 PM Post #1,590 of 3,150
Dear friend,
The LHDC in UTWS5 is 3.0 version customized by LHDC for adaptation to the Qualcomm platform. The HWA in FiiO Music app is not the same one so the M11Pro could not connect to UTWS5 via LHDC.
Besst regards
