The two pin version will be available early next month.is the two pin version not out ?
Best regards
Thanks a lot for these really helpful pictures!I can’t get any pictures at the moment of it attached to someone’s head but I’ll provide pics of it next to the utws1 for reference. It’s a little bigger but feels much better build quality wise. Also cause of the easily adjustable ear hook it’s extremely comfortable. At the end of the day it will still look like you have a hearing aid or something latched to your head hahaha
With the participation of the high-performance headphone amplifier chip, the UTWS3 has made great progress in terms of sound quality. Its independent amplifier architecture greatly increases output power to better drive multi-driver headphones. It also has an analog volume adjustment system, for improved dynamic range and signal-to-noise ratio for even better audio performance.
Rough estimate is 3.5 x 2.8 x 1.3 inches. I see no screws anywhere. This will definitely be a "pry apart" kind of adventure for you.For anyone that already has the UTWS3... would you please provide case dimensions? Additionally, does it look like there are screws or some way to open the bottom and get to the case battery? I'm thinking about options to gracefully retrofit Qi wireless charging. If there's a way in, I might fit a Qi receiver to the inside bottom of the case and solder it into the charging circuit.
Thanks. I might have to go for the none two pin type as your versions look like they don’t have a square shape fitting and get a adaptor that doesThe two pin version will be available early next month.
Best regards
Same question here, I'm wondering if the .78 mm version will fit the Moondrop Starfield's recessed connectors.Apart from the case, would the UTWS3 itself work with recessed 2-pin sockets?
Dear friend,@FiiO , could you please share with us real photos of 2pin version and pins length so we can do the calculations for our iem's recessed sockets =)
Thanks @FiiODear friend,
You could check whether this help you to confirm:
The length of the pin:
3.6±0.15mm
Best regards
Thanks @FiiO
I don’t think these will do for recessed sockets.
I can only hope you will leverage the engineering expertise that led to the LC-RE’s swappable plug and design true wireless receivers with swappable sockets. In fact, the reason why I won’t get the LC-RE itself is because of its doubtful fit with recessed sockets.
@FiiO Willson @FiiO
Your promotional image says "4-5times fully charge each ear unit" - what does this mean? Did you mean 4-5 hours?
How fast do the ear units charge? (Like how much time can I get out of a 5 minute charge? What about a 1 hour charge? etc)
