Like i said before, i unplug when battery charging case is full. And yes, the led in the box already on always on and not breathing. Still it's only in 1-2 weeks already empty, not in 4 weeks. Worst i can get in 1 week, it's already empty. That is why I'm asking this, why battery charging case empty in just 1-2 weeks. My warranty claim refused by seller on indonesia. I'm also already asking it to Fiio customer support by email.Hello,
Under normal conditions, the box can standby for 4 weeks.
The problem you are experiencing may be that the box is not fully charged. When the box is fully charged, the indicator light will change from breathing flashing to always on,
[FiiO UTWS3] True Wireless Bluetooth Module/MMCX/0.78 2pin/QCC3020/TPA6140A2/ Bluetooth 5.0
- Thread starter FiiO
I didn’t realize how much you could bend the utws3 until I matched them with m2s pro. Loving this setup!!
Introduction to FiiO's Product Line and Update Plan in 2021--From James
(https://www.head-fi.org/threads/int...ne-and-update-plan-in-2021-from-james.959256/)
Chapter 11 UTWS3/5 -TWS Solution with the Best Sound Quality.
There is one rule remaining unchanged for the many years I spent in the audio industry. That is, what drives the development of the product is not the performance, but the user experience. From reel to reel tape recorders, turntables, tape cassette players to CD players, MP3 players and TWS earphones, there is no denying that the sound quality has been improved constantly, but the main change of these products was providing a more comfortable and convenient experience.
When most people tend to listen to music via mobile phones and TWS earphones, the HiFi earphone market was sharply hit, especially for the famous brands such as BOSE, Sennheiser, Beats, and Audio-Technica. From the sales rankings of audio products in some promotion activities in 2020 and 2021 in China, we can see the top brands have become Apple, Huawei, Xiaomi, EDIFIER and other brands that mainly sell TWS earphones.
Therefore, these HiFi earphone brands shall either sit idle, or follow the market trend and meet user needs in order to survive in this giant-dominated TWS market.
The UTWS series was our attempt to adapt to the market. Here is a brief introduction to what determines the sound quality of TWS earphones.
1. Bluetooth codecs
You may be familiar with this point. At present, TWS earphones mainly support Bluetooth codecs including SBC, AAC, aptX, aptX HD, LDAC and LHDC. It is widely considered that aptX HD/LDAC/LHDC have better sound quality. However, limited by the bandwidth of Bluetooth transmission and signal power, the experience of these codecs at high bit rates has yet to be improved. Therefore, the more mature codecs should be aptX and AAC.
2. Digital-Analog conversion and analog amplification
At present, since TWS earphones are restricted by power consumption and size, we usually adopt a single chip, where D/A conversion, analog amplification, Bluetooth reception and decoding are all integrated into one piece.
3. Acoustic design- earphone cavity/unit
At present, TWS earphones have a relatively small size. Even if we use a good earphone driver or even multiple drivers, it would still get much worse performance than that of traditional wired earphones because of their tiny bodies.
The UTWS3 with such a TWS design happened to be the best solution that can solve the above No.2 and No.3 limitations that most TWS earphones have.
In fact, the UTWS3 is meant to separate the circuit part of the TWS earphones and put it inside the earphone unit while adding an independent amp chip. This helped to effectively improve driven capacity, SNR and distortion that have a great impact on sound quality. Users can freely use the UTWS3 with their favorite MMCX or 2-pin earphones, which is totally different from those typical wired earphones in terms of the acoustic part.
Thanks to its feature of retaining the convenience of TWS earphones while having great sound quality similar to traditional wired HiFi earphones, the UTWS3 is warmly adored and praised by consumers once launched.
Of course, both the TWS sound quality and ear hooks are improving as technology develops. In order to further enhance the sound quality, we will introduce the UTWS5 around October, a more powerful TWS ear hook model with better audio performance and more capable Bluetooth functions, which features an independent DAC chip and shares basically the same look and structure as the UTWS3.
Appropriate Usage Scenarios
The usage scenarios of the UTWS3/5 are mainly outdoor scenes. They are suitable for traditional HiFi earphone enthusiasts who want to enhance the experience of their existing wired earphones. In addition, you can turn your idle interchangeable cable earphones into more convenient HiFi TWS earphones.
1. Bluetooth codecs
So I've had my utws3 for about 3 months. I only use it for about 3-4 hours per week. But now my case barely charges. The light indicator on the case is red after charging my earbuds once.
And one of the two indicator lights on the case doesn't work at all.
Dear friend,So I've had my utws3 for about 3 months. I only use it for about 3-4 hours per week. But now my case barely charges. The light indicator on the case is red after charging my earbuds once.
1. The charging case may be out of battery after about 1months when keeping the earbuds in it without using.
2. And you could try to clean the earbuds following the help in this FAQ to check again: https://forum.fiio.com/note/showNoteContent.do?id=202105211656085546722
Best regards
thefallenangelx
Anyone knows if the Moondrop Variations fit inside the case? Thanks
- Sep 8, 2014
Has anyone tried to drive the Tin HiFi P1 Plus with the UTWS3?
grininja
- Feb 10, 2015
Hey Fiio! Will you ever "fix" the EQ so that custom EQ is possible? As per today I find it useless. I also have a BTR3K and a BTR5 and they are totally fine regarding the EQ.
Sorry to hear about that. Does the other EQ function work for your UTWS3 instead? And please try to clear the pairing and reconnect again for check.Hey Fiio! Will you ever "fix" the EQ so that custom EQ is possible? As per today I find it useless. I also have a BTR3K and a BTR5 and they are totally fine regarding the EQ.
Best regards
grininja
- Feb 10, 2015
It's not that EQ function does not work. It's that are only 3 predefined EQ settings and I can not adjust frequencies as I want to.Sorry to hear about that. Does the other EQ function work for your UTWS3 instead? And please try to clear the pairing and reconnect again for check.
Best regards
- Sep 8, 2014
For anyone that might be curious, I went ahead and picked up the P1+ and have been using it with the UTWS3.Has anyone tried to drive the Tin HiFi P1 Plus with the UTWS3?
I'm no expert on quality, so I'll leave that to others, but suffice to say, the P1s certainly impress me sound-wise. I feel like all the songs I listen to are new releases!
On the power front, I can be a little more helpful. I've set the internal amp on the UTWS3 at level 22 (there are a total of 24). The upshot of this is that the P1+ requires only about 50% volume from my iPhone. Bass, mids and treble all sound good and present. I'm using the foam tips, as the silicone tips do seem to have less bass oomph and a slightly stronger treble.
I hope this info helps.
- Sep 8, 2014
I too wish there was a way of customising your own eq within the app. It's the only thing that I feel is missing.It's not that EQ function does not work. It's that are only 3 predefined EQ settings and I can not adjust frequencies as I want to.
drftr
Posted the same question in the UTWS5 thread, but since (I think) the cases are the same size:
Does anyone know if the 7Hz Timeless fits into the case??
drftr
drftr
My charging box dont light on After a full charge.
What thé problèm ? Thanks
Do you mean all the 3 indicator don't light up? Please try to clean the pins, and open then close the case again for check?My charging box dont light on After a full charge.
Best regards
Total: 6 (members: 0, guests: 6)
