[FiiO UTWS3] True Wireless Bluetooth Module/MMCX/0.78 2pin/QCC3020/TPA6140A2/ Bluetooth 5.0
Sep 23, 2021 at 3:48 AM Post #811 of 908
I meant on the UTWS5. Is the feature on that ?
More information about the UTWS5, you could wait for our FiiO 2021 Autumn Launch Event II on September 28, 2021.
Best regards
Sep 24, 2021 at 3:34 AM Post #812 of 908
Is there any news on an update for the firmware for the UTWS3? There are still stability issues where the UTWS3 drops connection (forgets it all together at times) and you have to reset them to get the connection back.
Oct 2, 2021 at 2:52 AM Post #817 of 908
I have been working with the UTWS3 , noticed an ongoing battery drain , the case , if left untouched for a week will have it's battery almost drained , even without using the UTWS3 for listening at all. What should I do ?
Oct 4, 2021 at 1:34 PM Post #818 of 908
it also happens to me, I was disappointed, usually the charge should be kept at least for a week !!
Oct 4, 2021 at 9:51 PM Post #819 of 908
i saw the summary but I still did not see if the UTWS5s have the transparency mode.
Are you able to tell us if it will have this feature or not ?
UTWS5‘s transparency mode will soon be open for support in late October or early November.
Oct 5, 2021 at 4:15 AM Post #821 of 908
Hi, I want to ask about this UTWS3. I have it in a few months. But I have problem with the battery. Battery charging case is drained although I'm not using it at all. It's completely empty in just 1-2 weeks. Is it normal ? or there is something wrong already with my battery ? I try contact Fiio Customer Support, and they said that it's normal for battery charging case empty in 25 days. But it's only 1-2 weeks, it's already empty. Also, I have a few TWS, non of it's empty only in 1-2 weeks. A few months it's decrease, yes, but not that fast.
Oct 5, 2021 at 4:50 AM Post #822 of 908
We're already mid week, with one outage of our dear social media yesterday, so let's think about a product that's reliable and which we'll be using on a daily basis.
Todays review is about UTWS3 from FiiO, this is an MMCX / 2-Pin adapter for IEMs, that can transform any IEM in a TWS headset, basically giving us all more reasons to have fun while out and about~~
I tried my best to review it, share my impressions and feelings about it, so if you're around and need some help with it, I'm always here to help!
https://www.audiophile-heaven.com/2...-bluetooth-adapters-portabilitys-with-us.html
Oct 5, 2021 at 8:52 PM Post #823 of 908
Hello,
I'm very sorry for the trouble, the battery pack can't stay on standby for long because it needs to charge the earhooks and maintain its own standby work, which requires some power consumption.
It is recommended to unplug the power supply after the box and the earhooks are fully charged, so that the power will last longer!
Oct 5, 2021 at 10:54 PM Post #824 of 908
Hello,
So you mean battery charging case empty only after 1-2 weeks is normal ? Is that bad the quality of Fiio battery on UTWS3 ? Because non of my tws empty in just 1-2 weeks.
Sure I unplug the battery charging case after full, never leave it's charging more than 3-4 hour. But it's hard to know when the battery charging case is full (including the earhook it's self). In manual it's said that when charging the battery charging case when led stop pulsing. But in my case, the battery charging case stop pulsing after a few minute on charging. I used cable with watt info (baseus cable), although led stop pulse, it's still charging. Will stop charging after a few hour (0 watt).
Oct 6, 2021 at 6:17 AM Post #825 of 908
Hello,
Under normal conditions, the box can standby for 4 weeks.
The problem you are experiencing may be that the box is not fully charged. When the box is fully charged, the indicator light will change from breathing flashing to always on,
