BenKatz
@FiiO @FiiO Willson Thanks for the response! Got 3 question I'm really interested in:
1) I see you released the very compact LC-BT1 that has a dedicate AKM dac-chip. Why is it that you couldn't include a dedicated DAC chip in the UTWS3?
2) LDAC (or APTX HD alternatively) - while indeed, there's no such thing as TWS earphones with LDAC on the market (although according to leaks, Sony's upcoming WF-1000XM4 might have LDAC) - why is it that LDAC isn't present on any TWS solutions? Is it impossible to implement/eat too much battery?
3) Why did you chose to make the lid out of aluminum and the body out of plastic? Is there e technical reason? My only feedback about it is that although the aluminium looks good, there is a clear texture/visual difference between the 2 pieces, and the TWS3 as a result, when you look at the case, looks a bit like a "frankenstein"
As a side-note/feedback - I really hope that for your next TWS adapter, you make a "locking" mechanism for the lid hinge - it's a bit annoying on the UTWS3 that whenever I open it to take out my earphones, the lid does not stay "locked" open and I need to hold it with my finger - a locking one (like in every other TWS earphone case) that holds the lid opened would help a lot!
Thank you and appreciate your R&D for all these awesome products!
