Could maybe somebody take a picture from the side of someone wearing the UTWS3, where one can actually properly see the proportions of the unit compared to a normally sized male head?
The pictures on the Fiio Website and other pictures I could find so far are all taken either from a strange angle (where one can not really compare the proportions) or on small women`s ears...
got mine today, @FiiO Willson, any update on ambient switch? also, when I do call, only the side I pair has mic on, I'm using tws only, should I switch to tws+ to use both mic in calls?
Hello, thank you for your support!
1, Ambient mode only for test. I've had a few users ask for test firmware before, but it's a bit of to upgrade, if you're interested you can contact me privately.
2, When you are in TWS mode, only the main ear can talk, this is due to the characteristics of TWS mode; if you want both headsets to talk, it is better to choose TWS+ mode
Upgraded Sounds
With the participation of the high-performance headphone amplifier chip, the UTWS3 has made great progress in terms of sound quality. Its independent amplifier architecture greatly increases output power to better drive multi-driver headphones. It also has an analog volume adjustment system, for improved dynamic range and signal-to-noise ratio for even better audio performance. #FiiOUTWS3#FiiO
that's what I thought, but apparently it's not that straightforward. Some has to be activate or configured by the companies. Either way I'm not so sure
Unfortunately, very few phones support TWS+ even if they have the requisite hardware. It is up to the OEM to provide support in the software they bake.
Back to topic...I find that using tips that brings out a brighter sound would complement well with UTWS3. Perhaps maybe wide bore ones. Personally, my Sony IER-Z1R presents a slight warmer sound on UTWS3 compare to wired. While I love the stock Sony silicone, I had to change to Azla Xelastec for a leaner sound to balance the warmth brought by the UTWS3. Personal preference of course. Just thought I'd share.
Upgraded Storage
For you to get longer battery life, we have included a charging case with the UTWS3 providing up to 30 hours of battery life. The charging case is large enough to accommodate both the ear units and most earphones at the same time, making it more convenient for charging/pairing/turning on and other situations. Opening the case's lid automatically turns on the ear units, while closing the lid turns them off. Therefore, you can say goodbye to previous complicated operations. #FiiO#FiiOUTWS3
