[FIIO SR11] Streaming Music Receiver
Oct 1, 2024 at 11:50 PM Post #91 of 345
Has anyone of owner of SR11 tried to send with roon for example (or any other capable software for that) dsd direct to SR11 and output it as native to dac with SR11 usb output. Could you try that Skev source to SR11 and to your K11 and inform us...Thanks to anyone who respond....
Sorry, don’t have Roon, any DSD files or a PC/Mac… I’m just a simple boy with basic needs 😂
Oct 4, 2024 at 6:43 AM Post #92 of 345
Specs of device only show support for DSD as DoP so you cant get Native not that there is any difference using DoP.
Oct 4, 2024 at 8:58 AM Post #94 of 345
Not necessarily to do with it having no dac. Native DSD support is pretty limited in the Linux world, even less so on Android due to manufacturers not supporting these Os fully. If they don’t release it to the Linux kernel then it won’t support it. DoP is more widely supported for external DACs as it’s part of the USB audio specs. Look at the issues Eversolo has had with the DMP A6 and external DACs supporting Native DSD.
Oct 4, 2024 at 12:36 PM Post #95 of 345
CrystalGipsy thank on clarification....I just wished to know how to send signal/even dop/ to streamer who will transfer it to my aune s9cpro. Hope its possible with sr11...wouldn't like to order and return. I have some nice dsf albums and in this moment argon as streamer...and somehow I intended to try dsd stream although I believe that my FLACs are not with less audio quality....I have read lot of about this topic.
Ps. Also found info about A6 complications that you mentioned...
Oct 5, 2024 at 11:15 AM Post #96 of 345
it will send via DoP from Roon automatically nothing to do your side. As long as your DAC supports DoP. Any files over DSD256 will be downsampled as limit of DOP is DSD256. So your server may well not cope there if not a good i7 or i5 processor.
Oct 5, 2024 at 11:17 AM Post #97 of 345
@FiiO are there any plans to add support for Squeezelite?
Also when will the firmware be available to make it Roon Ready as the SR11 and not display as the M17? I see it’s showing as certified on Roons website now.
Oct 6, 2024 at 4:10 AM Post #98 of 345
Anyone else getting a lot of dropouts/pausing using Airplay? I don’t have any mesh networks and I’m in the same room as the router. I’ve been using my Shanling M1 Plus instead using Airplay and had zero issues.
Fiio is this fixable or an issue you are aware of?
Oct 6, 2024 at 6:52 AM Post #100 of 345
Tried again and it wouldn’t appear on the Airplay list. Went into menu to force a new “Connect” and seems to be working ok so far. 🤔 could be the router, hard to tell. Hopefully was just a one-off
Oct 7, 2024 at 3:32 AM Post #101 of 345
@FiiO may I kindly ask for the latest FW? Got the same issue of Roon disconnected in a minute or so, with the close and clear of connections 5GHz network (hap AC2). I do have V193 now. I would like to try both recent versions, if possible: main Airplay+Roon, and the one with DLNA. Thanks a lot.
Oct 7, 2024 at 5:36 AM Post #102 of 345
@FiiO using firmware 226 Roon Ready is crashing on device and drops off. Airplay still works mind as in Mix mode. Seems to be when moving a queue from another device and or when I switched from a pcm source to DSD source.
