emilsoft
- Dec 5, 2014
Does it do the same problem if you move it slower whilst menu scrolling (normal use case)?Moving it back and forwards, then it double jumps up two. Obviously not a real use case but when in menus it double jumps menu options etc. It wasn’t doing it before but if it’s expected and just some wear maybe I don’t send it back…?
Id try some pressures air on the volume through the cracks carefully though. Try to work it back and forth but in longer distances and slowly for a bit and see if it settles.
Even RME ADI2 dac had similar prob over time the resistors can become less sensitive or something - which is why they allow in fw user set tolerances to adjust for variability to fix it
