Hi Fiio, is it possible to buy a new Q5s with the amp module AM3D option?
[FiiO Q5s Type C ‖ Q5s] Bluetooth DSD-capable Amplifier,AK4493x2,768k/32bit
- Thread starter FiiO
showme99
- Nov 29, 2015
https://www.head-fi.org/threads/fii...pdif-line-input.902614/page-147#post-15328230Hi Fiio, is it possible to buy a new Q5s with the amp module AM3D option?
I see, it does come by default the am3d module....why didn't I just click the link before... Thanks
mrlobaloba
- Jan 24, 2016
I am using my Q5S with USB-out from my Galaxy phone, how much volume should I keep my phone at, it is bit surprising both the amp and mobile can charge volume.
Also does the Q5S support Quick Charge.
Sorry though if these are noob questions.
As far as I understand usb-audio, the volume should be controlled solely by the Q5s ie your phone will just feed digital signal to Q5s. No need to bother with adjusting your phone volume.I am using my Q5S with USB-out from my Galaxy phone, how much volume should I keep my phone at, it is bit surprising both the amp and mobile can charge volume.
mrlobaloba
- Jan 24, 2016
Which is what I expected i,e volume should be locked in my Galaxy Note 10+ apparently it's not I am able to change its volume as well as the Amp,
FYI I am using Spotify, haven't tried other players yet.
@FiiO What is the recommended volume level in Android here.
If I were you mrlobaba, it'll be fantastic if I can maintain the volume of the Galaxy Note 10 to acceptable sound level, then only adjust the Q5s volume, otherwise the next time you listen using only the phone, the sound would be boombasticWhich is what I expected i,e volume should be locked in my Galaxy Note 10+ apparently it's not I am able to change its volume as well as the Amp,
Keep your phone at full volumeWhich is what I expected i,e volume should be locked in my Galaxy Note 10+ apparently it's not I am able to change its volume as well as the Amp,
And dont forget to enable ldac
mrlobaloba
- Jan 24, 2016
Thank you guys.
Also do you happen to know if the Q5S support Quick Charge, there is no information from FiiO in this regard, I am just curious.
No it doesntThank you guys.
If one uses usb connection, why have to enable ldac? Isn't that only for bluetooth connection? Sorry if this question sounds weird...I've only connected to q5s from DAP and not from phone.
Yes you are right my faultIf one uses usb connection, why have to enable ldac? Isn't that only for bluetooth connection? Sorry if this question sounds weird...I've only connected to q5s from DAP and not from phone.
MotherGooz
- Feb 10, 2012
Using the Q5s only for spotify is a waste imo i hope you gonna use it to its full potential?
When you play DSD/FLAC with apps like the Fiio Player or Onkyo HF Player you will be asked to make it your standard USB device, meaning everything is passing trough the phone and to the Q5s, and you will not be able to change the phone volume, only on the Fiio (then the real magic happens) Android has LDAC support, try it, it sound great! (Wired is always better ofcourse)
Listening to DSD and see that green light shine on the Q5s is very satisfying
Wyllio
- Jan 9, 2015
Does anyone have issues with the Bluetooth playback buttons rattling when being tapped?
mrlobaloba
- Jan 24, 2016
Yes I agree, Its just that I haven't got a chance to transfer my music collection to my phone (I got the Q5S yesterday), soon I'll be transferring it and use the Q5S the correct way
