It's a Shanling L2 cable apparently used for connecting Shanling DAP to Mojo, costs me appr US22
Hi. Yes if connect to mojo there won't be any issue as Mojo has a seperate charging port but not for our Q5S.
Thanks for checking. I have Windows profile - "No Sounds" so it should turn itself off... What firmware do you have?Auto standby works for me. Just make sure that there's NO sound coming from your PC for 10-15 minutes. Mute it, if needed. Any sound will cancel the auto standby, even notifications.
It's not hiss, it's your breathing... Just look at your avatar man, what the heck!?I got the Q5s with the THX module and sound is pretty good. However, I'm hearing a decent amount of background hiss. Granted, I'm trying these with my new 4 ohm EE Wraith but compared to my other sources, it's the worse. I hear this both in wired and wireless modes. Is this consistent with what others are experiencing with sensitive IEMs?
No, what is the fw version of your Q5s, v0.37 or older? I tried different time settings in FiiO app.Windows 10 build 1903, pretty standard. No idea what's going on on your end, sorry. Maybe try reconfiguring the Q5s in the Fiio app? Just in case, you know.
Ah. I installed the 0.37 firmware, but I think the behavior was the same with the stock one.No, what is the fw version of your Q5s, v0.37 or older? I tried different time settings in FiiO app.
Hi
Can you please share what is the cable that you are using to connect your DAP to Q5S?
