I selected usb on the device then plugged in and let music play from uappLast time I tried it It did not work. Have you got to enable anything specific in the settings?
[FiiO Q5s Type C ‖ Q5s] Bluetooth DSD-capable Amplifier,AK4493x2,768k/32bit
- Thread starter FiiO
kaushama
- Jun 29, 2004
Thank you. Any specific changes to be done in the UAPP settings and drivers for better quality audio? I am gonna try Tidal HIFI with UAPP and Q5S.I selected usb on the device then plugged in and let music play from uapp
Buy MQA
Internal driver - Bitperfect mode, Use with BT output
Android Audio -Play through Android, Sample rate depends...
USB audio - Upsample off, Bitpefect on, Nativ DSD, No limit sample rate
Are there already new firmwares or bluetooth chip firmwares for the q5s. I got the one from the first batch
therighttone
Hey man! How do you like this combo so far? I'm also planning to get the FA7 with Q5s but i have never heard the 7 before. What can you tell me?When available in Romania!!? I have an Q5+FA7 best combo for me for now.
kaushama
- Jun 29, 2004
Q5S connected to my S10+ gives clicks and pops! UAPP or Neutron. Even when player is not running it clicks and pops! )-:
Sonic Defender
Look at buffer settings. I know that on my PC with JRiver Media Center and the Q5s I had a great deal of clicks and pops, but they were completely eliminated by playing around with the FiiO Control Center buffer settings, and the buffer settings in JRiver.Q5S connected to my S10+ gives clicks and pops! UAPP or Neutron. Even when player is not running it clicks and pops! )-:
kaushama
- Jun 29, 2004
Thanks But even without a player app connected it pops. I guess it is the cable? FIIO CL06 cable!Look at buffer settings. I know that on my PC with JRiver Media Center and the Q5s I had a great deal of clicks and pops, but they were completely eliminated by playing around with the FiiO Control Center buffer settings, and the buffer settings in JRiver.
Fiio control center ? Buffer lenght ? WHERELook at buffer settings. I know that on my PC with JRiver Media Center and the Q5s I had a great deal of clicks and pops, but they were completely eliminated by playing around with the FiiO Control Center buffer settings, and the buffer settings in JRiver.
Sonic Defender
On my PC, that is why I mentioned it. I am not sure if there are buffer settings with the other apps, but I thought it worth mentioning. When I have researched this rather common problem, clicks and pops with DACs my research revealed that buffer issues are the most common culprit and in my case they absolutely were the problem. That is the only reason I mentioned it at all, hoping that it might be the issue for the OP.Fiio control center ? Buffer lenght ? WHERE
Sonic Defender
Bummer, my bad, you did mention that. Have you been able to try another cable?Thanks But even without a player app connected it pops. I guess it is the cable? FIIO CL06 cable!
The programm is called fiio control center ?On my PC, that is why I mentioned it. I am not sure if there are buffer settings with the other apps, but I thought it worth mentioning. When I have researched this rather common problem, clicks and pops with DACs my research revealed that buffer issues are the most common culprit and in my case they absolutely were the problem. That is the only reason I mentioned it at all, hoping that it might be the issue for the OP.
Yes it very difficult to see and I think it may have been made from missing putting the line in cable. The aluminium is very soft. Still I would not want to send more time looking at the nick, I did get the Q5s to play music.I've got a small nick in the same place- right above the beveled shiny corner part. Aluminum is relatively soft so it can easily happen. Doesn't bug me much as you have to have have the right angle just right to even notice it.
What if i put it all the way up or the buffer rates will that be saved even for my phone
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
Yes stuff like that drives me crazy, but I'm getting better at living with little dings I swear mine had that out of the box. I like the looks of the new daps with front and back glass, but from a practical standpoint, the rubberized fake leather back is really nice.
Like zx300 and the flagship Sonys. And of course q5s.
