kaushama
- Jun 29, 2004
Battery life is less than what's claimed. However I should check battery life with Am3d. Supposedly THX tech drain less juice.
Fast charging to the best of my knowledge shortens the batteries life. How significantly I am not sure, but still never bad to treat batteries the best that you can.If it had fast charging capability would have been wonderful.
Sounds legit I am happy whit the load time but the battery really don't don't holdup like promisedFast charging to the best of my knowledge shortens the batteries life. How significantly I am not sure, but still never bad to treat batteries the best that you can.
I just tried in ldac maybe that is the problem why to hell they do somthing@Cevisi @abitdeef
Equalizer in blutooth menu of Fiio application is function of bluetooth module ONLY. Systemwide function means when any BT device is connected to Q5s. It does not work on any other input (USB,optical,...). I am almost sure but I don have block diagram of Q5s to confirm this. I dont know what is between BT or other inputs and DAC.
This is the same with my BTR3. Here firmware update tool (BlueSuite) is from Qualcom and it updates BT chip firmware only. I am afraid that the same situation may be for Q5s - only BT fw update, not other - DSD problem . We will see.
Another info - in BTR3 equalizer does not work for LDAC and BT chip is the same in Q5s so I would expect the same. This is info from Fiio.
@dark09 I see that there is a special Fiio update tool so there is some hope for DSD.
@MarkF786 To say the trueth I play music DSD about 40%, hires PCM 50% and 10% CD quality. Spoken word (discussions or audiobooks thru BT). Everything with USB Audio Player Pro. I use FiioApp only to check that every thing is switched off - no equalizer, no charging no everything. Not for playing or anything else.
And we have also answered you via email. Please have a check.
We checked your old email and found that we have already replied in the next day but did not receive any feedback from you anymore.
As for the FiiO forum, we reply the questions from our users daily, did we miss yours by mistake?
Those file are huge - not possible by email. I can upload somewhere. Where?But we failed to reproduce the problem you mentioned.
Maybe you could provide your music file to us for check?
On bluetooth, mine will do the same ie, disconnect the bluetooth connection, then blink once and then back to default input that is not bluetooth.
I have asked also UAPP team to add this feature separately for PCM and DSD. They are very helpful, they already added some feature for me so we will see. I don't want to use 2 different players in one device.Luckily there is a swap channels feature in neutron.
It does not work at all. When using ldac. I would like to know whyUseful info from Fiio in M11 thread: Question is if it works only for BT or also USB and other inputs.
I also never see FiiO answer questions about batterySomebody said here : Fiio can replace it easily. Really? Any prove of this? Yesterday I found in other thread somebody asked Fiio for replacement battery - Fiio response was We don't have such batteries. I also asked Fiio if there is possibility to replace battery in Q1mkII. No response.
