Dear friend,What is the Q5's line output voltage?
1.8Vrms.
Best regards
What frequencies did you check? I just did some further testing and 44.1kHz is fine but 48kHz occasionally pops (every few sec) and 96kHz brakes up all the time, 192 doesn't work at all.Optical - check (From my PC motherboard)
How do you think it compares to a Sound blaster X7 as a stationary USB/SPDIF/Bluetooth DAC/Amp combo for PC and console use?
Yeap, COAX is flawless on mine also. Tested all I got including some DSD tracks using D2P from X7. Ordered a $8 Optical to Coax converter but it will be a month until it get's here.48 kHz since that the max my PC will do. Only listened for a few minutes though. I will look for a higher res optical source and report back with a more thorough listening. Coax works flawlessly to the max 192/24 bit rate.
Thanks for taking your time to check.Well this sucks - I find out today that my latest model MacBook Pro 15 no longer has optical out! Sneaky omission by Apple. Guess no optical testing for Q5 then.
What frequencies did you check? I just did some further testing and 44.1kHz is fine but 48kHz occasionally pops and 96kHz.
Just BluetoothShould the Q5 Previous/Next track and Play/Pause buttons control USB attached devices or just Bluetooth?
Straight forward with given cables usb c and microHas anyone tried connecting the Q5 to an Android phone? Was there any hiccups or straight forward?
