thebrieze
- Feb 24, 2008
How can I get the FiiO app to play through BT (for EQ) in iOS?
The app will “play” a song without actually playing it (icons animated, play time does not change, no audio). The hardware buttons will play from iTunes and “stop” the animations in the FiiO app.
Also, the app only imported 4 songs (of many hundreds of song downloaded showing in iTunes) .. very disappointing first-use. Hopefully it’s simple / possible to make better.
Seems like something might be corrupted on your phone. Some things to try.
Check reviews of the app in the App Store to see if others have the same issue.
Reboot your phone
Delete the app and reinstall it.
Contact Fiio support, if you have the same issue after a reinstall.
