HulalaHifi
Finally I figure out how to make my Qobuz hi-res streaming playback to my Q5 DAC in DSD 256 format
Good day people.
Does someone has experience with the AM5 module ?
I use the Q5 only as an amplifier and with AM5 Its only 30% louder than the stock AM3A. That normal ?
Used as DAC and amp is little bit better, but still doesnt feel entirely right. I have the old Fiio E12a and JDS Labs C5, both are more powerful than this. For the C5 is normal, but the E12a is as well, and looking the specs of the AM5.....should not be so.
I have the Fiio X5 the first generation, i use the amps with it, or with regular computer. So thats the source.
Headphones used, from 32 to 300ohms, same result.
If the E12a is more powerful, looking the specs, the AM5 makes less than 400mW into 32ohms. I understand the device is intended to be used as DAC, not only as an amp, but after what i experienced, purely as an amp, its not very good at this.
Line out is very good tho...
I was just wondering if someone really uses this only as an amp sometimes, and what the observations are. Does it feels underpowered ?
Apart from this, no really problems with the device, Bluetooth, connectivity, all is fine, rock solid.
Hope this helps.
That seems odd, the HD 650 should be the more challenging to drive headphone. The AKG712 is pretty sensitive so not sure what might be happening. I wonder if the different sound signatures and how they present make the HD650 seem fuller and louder to you. I'll admit that I have never enjoyed the AKG house sound so I haven't owned any of their headphones.Mister, i thank you very much for your answer.
So my unit is completely fine and functions as it should be.
The E12a is with more forward mid tones i believe, and when you push it more it just sounds kind of harsh because this.
I have HD650 as well, and the Q5 with AM5 sounds completely fine with it. Its just for i have AKG K712, although in their specs its said 62 or 64 ohm (something like this was), they are somewhat harder to drive than the HD650 300ohms and from there i just was wondering if my Q5 is OK.
I dont have any DSD recordings to try the Q5, but i will search for some soon.
I thank you very much one more time.
I don't have AGK712, but I have AKGQ701, and I found they are harder to drive using Fiio/AM5 compare to Sennheiser HD650 .That seems odd, the HD 650 should be the more challenging to drive headphone. The AKG712 is pretty sensitive so not sure what might be happening. I wonder if the different sound signatures and how they present make the HD650 seem fuller and louder to you. I'll admit that I have never enjoyed the AKG house sound so I haven't owned any of their headphones.
Again, trying to understand what about their design might make this possible. So with speakers, generally speaking, cabinet volume has a direct relationship with the maximum volume that can be achieved with the design. I am sure there are other factors, but the relationship is there. I wonder how this translate to headphones, which are ultimately just speakers so perhaps there is a difference. Does the HD650 have more enclosure volume and hence play louder? Not sure, but looking at the specifications, the Q701 or 712 are objectively not harder to drive so clearly there are other design factors at play.I don't have AGK712, but I have AKGQ701, and I found they are harder to drive using Fiio/AM5 compare to Sennheiser HD650 .
I have the FH5 with a Linsoul gold 2.5mm cable and have barely any hiss at all. Only noticeable on completely quiet passages at reasonable volume... So, not sure? Do you have the gain set to low?I'm plugging Fiio FH5 with LC-2.5C into the balanced jack of Q5, is it normal to have hiss in those configuration?
Its the default amp module
yes, its on low, and yes it's only noticable on quiet passages, but it's quite noticeable i think, i set the volume at 9 o clock, it's audible even when the volume is on 6 o clock.I have the FH5 with a Linsoul gold 2.5mm cable and have barely any hiss at all. Only noticeable on completely quiet passages at reasonable volume... So, not sure? Do you have the gain set to low?
I use predominantly IEM'S, and the amp module that comes with it is fineHi,
What amp module would you recommend for low impedance IEM and 24ohm headphones?
