DJtheAudiophile
- Dec 7, 2016
Will this work with the iPod nano?
Sub-par to your standards or needs but not everyone else's. If someone needs a cheap DAC/amp for the laptop then this is the route to go. I wouldn't expect all the bells and whistles at this price point so I'm not sure what your issue is with this device. Compared to the original Q1, it's an upgrade and the original Q1 was an entry level DAC/amp that cost $69. This one is $99 and does balanced. If you want more than that, then get your wallet out because all those extras you want cost more money. It's pretty obvious this device doesn't meet your needs, but that's not a reason to call it sub-par.
If only need a convenient use and do not want to spend too much money, of course, the most suitable is Q1MarkⅡ.
FiiO never advertised it as such. Read the marketing material. Firstly, they've designed it for use with iOS devices now that the headphone jacks are going (smart move). Should be compatible with a lot of Android too. USB audio out for laptops etc. Its a $99 device.But the problem is that it's inconvenient without an RCA jack for digital audio.
I think removing the headphone jack is a bad idea. Try charging your iPhone 7 while listening to something with headphones. Can't be done. it also means having to carry around a small cable to be able to use headphones. So really, this was not a good idea.
I'm not an apple user outside of occasionally buying music from iTunes. If I recall, they were pimping their bluetooth earpods rather than being wired so technically you can charge your phone and listen so long as you use bluetooth. Perhaps there's some type on multi-port OTG adapter one could use as well, but I really don't know.How can one charge an iPhone 7 while using headphones? Streaming video or playing a game can drain the battery. So if I want to do something that makes sound and I also need to have the phone on charge while doing so yet a nned to use headphones, how do I do this? That's what makes taking away the headphone jack a very bad idea.
As for the Q1MII, is there some adapter that would adapt an RCA DAC cable to one the Q1MII would accept?
Q1 MKII does balanced and single ended out.I was intrigued when I first heard about the Q1 MKII but now I see it will be of no use to me and I will stick with my Q1 as I don't have balanced headphones and no plans to upgrade. I really don't need the DAC from the Q1 as I only use the amp section with my A17. At this point I wish that Fiio would finally upgrade the A3 which is just a rebadged E11K as it is very long in the tooth by today's standards. The amp section in the Q1 while not as powerful as the A3 sounds better to me as I have both and offers almost double the battery life. The A5 is to much power for my needs and the battery life is even worse than the A3. The E12A was kind of what what I am hoping the next A3 will be, essentially a less powerful and cheaper amp than the A5 with 20 to 25 hours of battery life.
Kind of getting frustrated with Fiio's new products as the Q1 MK2 is of no use to me. The X1-II comes up short on performance and features and the X5-III and X7-II are android based and of no interest to me. I was holding out hope for the X3-III and it does look really nice but lacks AptX bluetooth support and has disappointing battery life. I wish Fiio would clarify the AptX question as the video on their facebook page shows Quallcomm AptX support but the features and specs on the site make not mention of it.
Wow. Looks great.
