The DAC has arrived. Slightly thick and did not fit into the phone stand. You'll have to make a new one and print it on 3d printer. I won’t write anything about the sound yet. It takes some time to listen.
FIIO Q15 DAC and Headphone Amplifier Discussion & Impressions Thread
- Thread starter FiiO
neobandog1
With newest firmware when in deskop mode everytime gain automatic on ultra gain?
This is stupid will be better memorize previous settings for gain..i don t need automatic ultra gain but deskop mode to bypass the battery and have ultra gain in option but not automatically enabled only manual will be far better not every time go-to settings and change to previous gain mode?
Chieffred
no it's only if you are in desktop mode AND you feed the USB C charging port that you will be put in ultra gain. if no USB C charge the gain stay the last one used. I agree that it can be bother some but maybe in the future ?With newest firmware when in deskop mode everytime gain automatic on ultra gain?
Great selection. The FiiO FX15 is currently one of the most interesting iem at the market with it’s electrostatic drivers. I also like the design very much.I have FDX and FX15, the FDX being the nearer in conception to FD5 (basically FD7/X are considered as having the same sound tuning as FD5 but with alittle more soundstage, mids, bass and treble but again with the same kind of tuning) and with Q15 which is on warmer side no hiss with both FX15 and FDX, on Q7 it can happen as it is a neutral tuning and so treble are not tammed by a touch of warmth.
Is it sound wise a good fit with the Q15?
neobandog1
Q15 sounds good with all iems and headphones have balanced transparent sound non fatigue to play liquid sound from everything but i don t have electrostatic iem never tested
I installed Q15 xmos v1.59 firmware successfully without problems, but later tried to install v1.66 and got "brick". Apparently this is a widespread problem. And it’s not clear from the documentation how to reset to factory settings, does anyone know?I can't find the instructions for installing the firmware on Q15.
How safe is it?
In the forum, one wrote that he received a brick after installation.
Today I flashed it to 1.66 without problemsI installed Q15 xmos v1.59 firmware successfully without problems, but later tried to install v1.66 and got "brick". Apparently this is a widespread problem. And it’s not clear from the documentation how to reset to factory settings, does anyone know?
I updated to 1.66 and had no problems.I installed Q15 xmos v1.59 firmware successfully without problems, but later tried to install v1.66 and got "brick". Apparently this is a widespread problem. And it’s not clear from the documentation how to reset to factory settings, does anyone know?
Inside the zip file “Q15 XMOS V1.66 Firmware.zip” is a word file.
Did you follow this instructions?
Indide the zip file “Q15 XMOS V1.66 Firmware.zip” is a word file.
Of course. The instruction is almost the same as for v1.59, the difference in section: "8. If Updating is displayed for more than 5 minutes, you can re-insert the USB cable and open the upgrade tool to upgrade the firmware again. After the upgrade is complete, the device will reboot. If it still shows Updating, you can press and hold the power button for 10 seconds to reset, and then try to upgrade again. However, please note that if the machine is reset twice during the upgrade process, it will cause the machine to malfunction and fail to boot. It may be necessary to mail the machine to us for repair." As far as I remember there were no two reboots.I updated to 1.66 and had no problems.
You can turn off auto-switching to Ultra Gain in the settings.With newest firmware when in deskop mode everytime gain automatic on ultra gain?
neobandog1
When will see this setting with newest firmware because i don t upgrade firmware yet?
Hi there, I seem to have some significant connection issue with Q15 to my smartphone.
On "default mode" (both phone+desktop mode off status) it keeps showing these reoccurring error messages like 10 times per minute as attached and doesn't play music at all.
If I only activate the "phone mode" (desktop off), it seems to get connected to my smartphone successfully and plays music, however even on "phone mode" occasionally it fails to play music. To troubleshoot this matter, Q15 either requires multiple reboots or converting to "desktop mode" first and then returning back to "phone mode".
The only mode it plays music constantly without any issues, is when I use the "desktop mode" (phone off) setting while it being connected to the AC outlet simultaneously.
Is this an user error or rather an internal software issue? This constant connection issue prevents me to use q15 on the go.
In general, what is the proper usage of q15 when a smartphone is used as source? @FiiO Willson
Use "Phone mode ON" on the go, this way Q15 uses internal battery, not the source's one. Seems, your phone can't provide enough power to Q15 when you turn "Phone mode" OFF - that's the reason of these flooding notifications on the phone.Hi there, I seem to have some significant connection issue with Q15 to my smartphone.
On "default mode" (both phone+desktop mode off status) it keeps showing these reoccurring error messages as attached and don't play music at all.
If I activate the "phone mode on" only, it seems to get connected to my smartphone successfully and plays music, however even on "phone mode" occasionally it fails to play music. To troubleshoot this matter, Q15 either requires multiple reboots or converting to "desktop mode" first and then returning back to "phone mode".
The only mode it plays music constantly without any issues, is when I use the "desktop mode" setting while it being connected to the AC outlet simultaneously.
Chieffred
Yes the Q15 tame a little the treble that could have been piercing with something more neutral so yes good combination and FX15 benefit of the reserve of power of the Q15Great selection. The FiiO FX15 is currently one of the most interesting iem at the market with it’s electrostatic drivers. I also like the design very much.
