FIIO Q15 DAC and Headphone Amplifier Discussion & Impressions Thread
Jan 7, 2024 at 6:01 PM Post #348 of 784
@trashkpi :
On which firmware version are you ?
Have tried a reset of your dac ? ´cause never had this problem except with my Q7 once and rebooted phone + reset of the dac and everything fine after that (I’m talking about the phone mode not working)
The last firmware - 1.66
Factory reset didn't help, connecting to another phone (Samsung fold5) didn't help as well.
Now it works only when external power is connected.
The strange thing is it worked in phone mode when I tested all modes right after receiving.
Jan 7, 2024 at 8:42 PM Post #349 of 784
Lol, today I decided to run q15 in portable mode without any success.
Q15 battery is 58%, desktop mode is off, phone mode is on.
I'm getting the attached message.
My phone is Samsung S20+
@FiiO Willson
Dear friend,
Please try to enable desktop mode and phone mode to see whether the issue remains?
Our engineer has got to learn about this problem with the Samsung mobile phone. And we will try to improve about that in later firmware update.
Best regards
Jan 7, 2024 at 8:44 PM Post #350 of 784
One more thing I have noticed - Gain settings are screwed up.
When you
set Low - got Medium
set Medium - got High
set High - got Super High
set Super High - got Super High
Dear friend,
How do you confirm this issue? Switching between high and super high gain, the volume doesn't change?
Best regards
Jan 7, 2024 at 8:51 PM Post #351 of 784
Anyone having issues connecting to an iPhone via USB? I’ve tried a number of cables, phone mode is on, and I’ve tried both USB modes. No luck.
USB connection works to a Mac however.
Dear friend,
Does your iPhone fail to recognize the Q15? Please check whether the USB cable you are using have the OTG function?
Best regards
Jan 7, 2024 at 9:47 PM Post #352 of 784
I've had this problem,
My q15 each time you click "next", or select a new track, in each case while another track is playing, there is a pause (which is normal) followed my a clicking/popping sound before it plays the selected track.
Clicking/Popping sound when switching between songs with different bit and sample rate.
I'm using Qobuz (thru the UAPP Android app), but this also happens with Tidal.
Does anyone else have the same issue?
Jan 8, 2024 at 7:55 AM Post #356 of 784
Dear friend,
Best regards
Hi,
I tried to reproduce the issue today but failed - everything worked as expected.
The phone reboot or the q15 factory reset somehow solved the issue.
Jan 8, 2024 at 11:35 AM Post #358 of 784
Hi!
I can't update my Fiio Q15 via a PC with Windows 11, what steps should I follow exactly?
I have downloaded the Fiio USB DAC controller as shown in the image (V5.58.0) and also downloaded the firmware 1.66
When I open the V1.66 firmware executable, the Fiio Q15 does not appear as connected and therefore I can no longer update
Is there something I'm missing or doing wrong?
Thanks
Jan 8, 2024 at 11:41 AM Post #359 of 784
Привет!
Я не могу обновить свой Fiio Q15 через ПК с Windows 11. Какие именно действия мне следует выполнить?
Я загрузил контроллер Fiio USB DAC, как показано на изображении (V5.58.0), а также загрузил прошивку 1.66.
Когда я открываю исполняемый файл прошивки V1.66, Fiio Q15 не отображается как подключенный, и поэтому я больше не могу обновлять
Есть ли что-то, что я упускаю или делаю неправильно?
Спасибо
The archive with the firmware contains step-by-step instructions. I did everything according to it, and everything works.
Jan 8, 2024 at 11:46 AM Post #360 of 784
Hi!
Thanks
Hello,
Inside the zip file “Q15 XMOS V1.66 Firmware.zip” is a word file.
Did you follow this instructions? It’s very important.
