duffer5
It is about 24-30 inches. Not sure but you will need the two components aligned closely together. Maybe a foot or two apart.how long is the cable that goes to the device?
Not sure I would ask @FiiO directly. They may have one or there maybe a 3rd party.No way to get a longer cord? Thanks
Dear friend,No way to get a longer cord? Thanks
Dear friend,I know the K9pro doesn’t need the PL50 but is there any improvement at all by pairing them together ? Is anybody currently doing this ?
As FiiO noted above, no. Why?I know the K9pro doesn’t need the PL50 but is there any improvement at all by pairing them together ? Is anybody currently doing this ?
Dear friend,I just received a US version PL50 that I plan to use with the Q7, however I don't have the Q7 yet (and won't for a couple of weeks) so I can't check that the PL50 is working properly (I don't think I have anything else compatible). However, I did check to see that the PL50 turned on and was wondering if it was normal for the front display showing the voltage selected to remain on even after I turned the unit off? If I pull the power cord, the display does turn off after a few seconds.
Thanks for the helpful response. I feel more than a bit dumb--I misinterpreted the symbols on the power switch and was turning the unit on when I though I was turning it off. When properly turned off, the display does quickly wind down to zero and turns off after a few seconds. As I noted, I don't have anything to check out the operation of the PL50 ATM (I won't get the Q7 for at least ten days and I have nothing else compatible with it), but it appears to be fine.Dear friend,
Please check whether the front display keeps remaining on after turning off the PL50? Or the front display turn off after a few second instead?
After turning off the PL50, there will be remaining voltage in PL50 and it will take some time for it to release. So if the front display turn off after a few second, it is normal.
Best regards
Dear friend,Thanks for the helpful response. I feel more than a bit dumb--I misinterpreted the symbols on the power switch and was turning the unit on when I though I was turning it off. When properly turned off, the display does quickly wind down to zero and turns off after a few seconds. As I noted, I don't have anything to check out the operation of the PL50 ATM (I won't get the Q7 for at least ten days and I have nothing else compatible with it), but it appears to be fine.
Dear FiiO,Dear friend,
Thanks for the kind feedback. Hope you could enjoy the Q7 and the PL50.
Best regards
I can’t speak for everyone’s experience, of course - but when I order something from the FiiO’s official store on AliExpress, those estimates are very conservative. I live in the eastern USA, and AE orders generally take about 2 weeks, sometimes a little more. The (much better) exception being for more expensive items such as DAPs, etc… where it only takes 3-4 days, since they ship those with DHL instead of the regular China Post & USPS.Dear FiiO,
On your official store in AliExpress, the estimated delivery date for PL50 is Feb 28. I wonder if that's conservative estimate and if I can expect to receive it sooner.
Regards,
Thanks for the feedback!!I can’t speak for everyone’s experience, of course - but when I order something from the FiiO’s official store on AliExpress, those estimates are very conservative. I live in the eastern USA, and AE orders generally take about 2 weeks, sometimes a little more. The (much better) exception being for more expensive items such as DAPs, etc… where it only takes 3-4 days, since they ship those with DHL instead of the regular China Post & USPS.
