Yes I know this. But I’d like it to play from the top directory, else why show the play icon next to it?
Ok, simple solution to your problem is to remove the play icon in the top directory.
Exactly! Nothing irks me more than unfinished or incorrect UI elements, and UI grammar errors (don’t get me started on those). But maybe that’s just me.Ok, simple solution to your problem is to remove the play icon in the top directory.
How do you update Tidal?updated tidal to the latest and masters are available for playing with yellow led on fiio logo
Downloaded apk from apkpure and installHow do you update Tidal?
This is used when using the 2.5mm balanced output.Good question. No idea! Can’t notice any difference with it on or off....
Thanks, wish it had EQ (or that the M9 EQ was system wide).Downloaded apk from apkpure and install
Got a pair of FH5’s delivered today. All I can say is a bloody marvellous! Have now turned the EQ off. These IEMs are near perfect for me. Happy chappy.Thanks, wish it had EQ (or that the M9 EQ was system wide).
I have the FH5 as my only IEMs and would still like system wide EQ to play around with some tweaks.Got a pair of FH5’s delivered today. All I can say is a bloody marvellous! Have now turned the EQ off. These IEMs are near perfect for me. Happy chappy.
Would still love a system wide EQ for some of my other headphones though.
