I've been able to work through or around most of my early issues but there are a few things I can't seem to figure out.
1. Syncing playlists:
a. Is there a specific location that the .m3u playlist files from my PC need to be saved? I can see the files in SD Card > Playlists, and I did a music scan just to be sure, but those playlists aren't showing up in FiiO Music at all. I also tried .m3u8 files.
b. Does anyone know where the playlists that are created on the device are saved? I tried to find that location on the SD Card and in internal memory to try to save the playlist files there, but couldn't find it.
c. Playlists created on the device are not syncing back to MediaMonkey even though I have it set up to import playlists from the device.
2. Syncing metadata from the M9 to MediaMonkey; such as last played and play count. When I sync the M9 (again, I have the appropriate option selected in MM), I'm not seeing play counts or last played dates changing.
3. I've also noticed that there are some albums that are in the folder structure of the M9, but aren't showing up in the FiiO Music app at all. I scanned for songs and they still aren't showing up. I double checked to ensure they were a supported file type.
I've rebooted to see if that changes anything for each of these issues and it hasn't.
I'm new to the high res digital audio game, so any and all help is much appreciated. Thanks!
@FiiO @JamesFiiO
