FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
post-15092566
Post #2,056 of 2,395
theadmans
Will Neutron provide better sound quality than Fiio Music?
Also having just installed Neutron and chosen DLNA and Foobar2000 runining on my Windows PC the scan is taking forever.
I have about 4GB of music stored in folders.
I only want to select by folder (I do not trust the tagging).
In this case do I need to wait for the scan to finish ?
post-15092735
Post #2,057 of 2,395
allaces305
Miami,Florida
Miami,Florida
Ok so I downloaded Viper HiFi and it seems to open up but it's totally in Chinese and I can't get past the second screen which seems to be some sort of login screen... Is there a way to log in and then change the language??
post-15093967
Post #2,058 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Dear friend,
No. This app only support Chinese currently.
Best regards
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
post-15093973
Post #2,059 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Not on my Android smartphone.
When clicked it changes to a white page and then back to the link list.
Dear friend,
Try another browser? I tested in my mobile phone and it work?
Best regards
post-15109344
Post #2,060 of 2,395
MarkBahamut
Santiago, Chile
Santiago, Chile
I installed the new FW 1.0.5 and i can tell that the distance range of using the LDAC Quality codec somewhat improved.
However if i use the LDAC Quality and Fiio Link at the same time the range is less and loading the albums picture on the Fiio's link Client (phone), it makes crackings due to the image transfer... but its only on that transfer, maybe on LDAC Quality is using all the bandwith.
I'm happy with this change because with FW 1.0.4 using the m9 and the speaker with LDAC Quality the distance range was like nothing (between the m9 and the speaker).
Hope that it may improve more on the next FW update,
I expected an update on the Fiio Music app that from the "now playing" display we could go easily to the albums display of the artist of the playing song by swiping up or right, or maybe touching the albums name on the description. @FiiO Please consider this on a future update for the Fiio Music player on the M9. It may improve the UI/UX. Is the only thing i miss that it was on my Ipod Classic.
post-15110173
Post #2,061 of 2,395
Santojob
With Firmware 1.0.5 the versions of Neutron and others expire. How do we install versions of payment on the Fiio M9? or others that we have registered on Android. We do not have Google Play installed ....
post-15115011
Post #2,062 of 2,395
pawdog
You will have to buy the non Play Store version from their websites.
post-15118926
Post #2,063 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Dear friend,
Thanks for your kind feedback. We will report to our product manager about that.
Best regards
post-15118931
Post #2,064 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
post-15118958
Post #2,065 of 2,395
Santojob
Dear friend,
Or you could download this app from our website: https://www.fiio.com/newsinfo/139014.html
Best regards
In the end I decided to install the latest paid version of Neutron, from its website. It cost me a lot for the configuration of the mail for the confirmation of the registration. At the moment it is working well.
Regards
post-15132034
Post #2,066 of 2,395
NeoteriX
This is a bit of an oddball question, but has anyone tried the USB DAC functionality of the M9 with a Chromebook? I'm wondering if Chromebooks are more like Macbooks with native support built in, or if a driver is needed (in which case it would be a non-starter on a Chromebook)
post-15137137
Post #2,068 of 2,395
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
Bucharest, Romania
Age
25
Website
audiophile-heaven.com
Quick question, would adding an external dac to the M9 make it sound better?
I was thinking of something like the cobalt for MQA?
Depends on the DAC, haven't heard that one in particular to say, but you may like it better together. Not fully sure if they work together tho
post-15137174
Post #2,069 of 2,395
Typhoon1944
Scotland
Scotland
I returned my M9 because of the terrible WiFi dropouts but from memory, it already decodes Master Quality Audio files from Tidal and HiRes files from Qobuz and sound quality was excellent, when it would actually play them over WiFi. Offline files played well also. Why would you want to add in another DAC?
post-15137210
Post #2,070 of 2,395
dharmasteve
London, England
London, England
The balanced output (2.5mm) will drive nearly all IEMs powerwise so I doubt if you would need an external amp. I have used various amps, just to test them against the M9, and the M9 more than holds it's own in terms of sound quality.....IMHO.
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
