FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
Discussion in 'Portable Source Gear' started by JamesFiiO, Aug 10, 2018.
129 130 131 132 133 134 135 136 137 138
140 141 142 143 144 145 146 147 148 149
  1. danblakemore
    Thanks fo this. I wasn’t aware it decoded MQR. So if tidal says master I should assume it’s decoded ok!
    (Sorry new to all this, my first DAP!)
  2. Typhoon1944
    The FiiO logo lights up in different colours depending on the type of file its decoding but I can't remember what is MQA. Green sounds familiar. Check the instruction manual in the support tab on the device. It will explain more in there.
  3. cristox
    The android app can decode MQA, yes.
    But it is decoded just in software and therefore limited.
    The Fiio hardware (DAC) is not capable of decoding MQA directly.
    To decode MQA in the best possible way, you need a external DAC with MQA hardware decoding.
    You have advantages, listening to MQA via just the Tidal app, opposing to "HiFi".
    Decoding it with an additional DAC should be better in theory.
  4. Brian Oneal
    Has anyone noticed a huge drop in the music library scan speed after the 1.05 update? It is quite drastic.
  5. FiiO
    Dear friend,
    Thanks for your kind feedback. We will also report to the engineer for checking about that.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  6. Pesplayer
    Yes. Hiby Music App is one of the best,incredibly quick,stable,makes the most of the sound. I have put it on the M11 and often default to it. But,alas,can’t get it on the M9. Rilliant piece of soft wear.
    Dobrescu George likes this.
  7. Marcobm23
    Please, include Hiby Music app on the white listed apps
  8. allaces305
    Yes please white list the hiby app.. It's a great app.
  9. FiiO
    Dear friend,
    The Hiby music app could not be installed in the M6/M9. A user tried to manually diy and installed it but failed as well.
    Best regards
  10. cbl117
    Hi, can someone confirm if the stuttering problem still exists if you use LDAC (Quality First) and WiFi at the same time? I am planning to buy this DAP to use with X1000M3 and sometimes stream from Tidal. I was hoping to get the full stream rate of 990kbps.
    Is the only workaround to use LDAC (quality first) with Tidal offline mode and WiFi off?
    Also, I was planning to use the M9 with my FiiO FA7. Can anyone comment on whether this is a good pairing?
  11. cbl117
    Please disregard my previous post. I read through all 139 pages and got my answer regarding LDAC lol.
    If my usage is mainly wired with IEMs and downloaded Tidal content, are there any other players at this price point that would compete?
    On occasion, I will be using BT with Sony 1000xm3, and I’d like to use highest quality LDAC, but I don’t see myself streaming tidal at the same time because I’ll be on an airplane lol.
    Given my usage scenarios I’m expecting the need for WiFi OR BT, but usually not at the same time. I don’t know if there is another option at this price point?
  12. cocolinho
    Hi!
    I do have an issue with the bluetooth . I cannot connect any of my phones to the M9. My M9 works as BT decoding amp mode (so as receiver) but not as BT transmitter. So I cannot use Fiio link to control my M9 with my phone.
    I tried all I can do but it simply do not connect. Just for 1 second actually, that's it...
    Did you already face this issue ? Thanks
    @FiiO
  13. FiiO
    Dear friend,
    If you are using the Fiio link in Bluetooth mode, you may read this for reference: https://www.fiio.com/newsinfo/162385.html
    Or you could try the Fiio link function in Wifi mode instead?
    Best regards
  14. cocolinho
    @FiiO actually I have an issue to connect my phone with my M9 using BT. I don't even talk about Fiio link yet :)
    My M9 simply refuses to connect to any of my phone by BT
  15. danblakemore
    Would additional by a chord mojo improve this device?
