AndySocial
Dear friend,
Thanks for your kind feedback.
It was the previous design plan for the M5 but not the final design. As for the final parameters, you may refer to our website soon. The M5 would support lossless BT transmitting LDAC instead.
Best regards
LDAC is a lossy codec, as are all available Bluetooth codecs. It's based on modified discrete cosine transforms, and is a very high-performing codec, but not lossless. I suppose it could be considered lossless (effectively, if not technically true) if the source audio doesn't exceed the data transfer rate available (up to but not guaranteed to be 990 kbps).
