littlenezt
deletedOk, please pm me the receipt and inform me the seller's name.
Thanks in advanced!
Best regards
Thanks in advanced!
Best regards
Thanks for the review. Perhaps the engineer thinks that it will be awkward to have 3.5 cable hanging out from your wrist.Hello everyone,
I've just received the SK-M5 A. It is good quality and seems pretty solid.
Some disapointment :
- no hole for the jack 3.5,So the M5 will be only useable in bluetooth or with an external dac on USB.
- Hard to remove for changing sd card or use jack cause you need a cross-head screw (which is included in the box of the SK-M5 A)
And a question, how could we make transfer files in bluetooth or wifi ?
Thanks
The unit is bugged with various glitches as the ones you mentioned.
Sometimes screen is not responding especially when hi res files are being played.
@FiiO should iron the UI with a firmware update.
As for power it can drive my FH7 to ear bleeding levels so I don't know what is happening with yours.
That's why I am asking, maybe it's because I paired F5 with X5 3rd gen.I have tried them with K3 , M9 and M11.
Now I don't understand well , do you mean that F5 provide more clarity than FH7?
No way!
Haha. Thanks. I like M5 for its portability but surely eyeing for M11 or M11 ProIf you can afford it is nigh and day.
Heck even the M9 is miles ahead of M5.
M5 is your invincible every day entry level friend and that's it.
Thanks in advanced!
Best regards
Dear user,ok was some how able to figure it out but how do you rename playlists i mean the m3u even i add them player keeps saying file not found
