Riolist2
- Oct 10, 2014
I wonder if the M3 supports podcasts like the Clip+ or has a way to bookmark progress like in rockbox.
I love bookmarks. Such a useful but neglected feature.
yes, not so many detail but you can feel the music especailly when you play mp3 music.
Hi James,
When will the M3 available in India?
Thanks.
Still not on Amazon in the US![]()
soo...
The only reason to buy the X1 over the M3 is 24/96 support ?
Model/Number | M3 | X1 |
Dimensions | 74 mm× 39.7 mm× 9.1 mm | 96.7 mm×57.7 mm×14.1 mm |
Weight | 40 g | 106 g |
Line Out | N/A | Standard 3.5mm headphone Port |
Digital Out (Coaxial) | N/A | Standard 3.5mm Headphone Port |
Volume Control | 60 steps digital potentiometer | 100 steps digital potentiometer |
Balance | 10 dB | 5 dB |
Internal Memory | 8 GB | N/A |
Expansion Memory (Maximum) | 64 GB | 128 GB×1 |
Output Power 1 | >50 mW(16Ω/THD+N<1%) | >100 mW (16 Ω/THD+N<1%) |
Output Power 2 | >30 mW(32Ω/THD+N<1%) | >65 mW (32 Ω/THD+N<1%) |
Output Power 3 | N/A | >8 mW (300 Ω/THD+N<1%) |
SNR | ≥95 dB (A-weighted) | >110 dB ( A-weighted) |
Output Impedance | <0.4 Ω(32Ω) | <2 Ω(32Ω) |
THD+N | <0.008% (1 kHz) | <0.003% (1 kHz) |
MAX Output Voltage | >2.8 Vp-p | >4.2 Vp-p |
MAX Output Current | >70 mA(For reference) | >130 mA (For reference) |
Battery Capacity | 550 mAh | 1700 mAh |
Battery Life | >24 h (32Ω; normal volume with display off ) | >12 h (32Ω; normal volume with display off ) |
Charging Time | <2.5 h | <4 h (DC5V 2A recommended) |
Lossless: | APE(Fast): 48 kHz/16 bit; APE(Normal): 48 kHz/16 bit; APE (High): 48 kHz/16 bit; FLAC: 48 kHz/24 bit; WAV: 96 kHz/24 bit; | APE (Fast): 192 kHz/24 bit; APE (Normal): 96 kHz/24 bit; APE (High): 96 kHz/24 bit; AIFF:192 kHz/24 bit; FLAC: 192 kHz/24 bit; WAV: 192 kHz/64 bit; WMA 9.1 Lossless: 48 kHz/24 bit; Apple Lossless: 192 kHz/24 bit; |
Lossy Compression: | MP3、WMA、OGG、M4A(excl. raw .AAC and .M4A encrypted ALAC) | MP2、MP3、AAC、ALAC、WMA、OGG... |
soo...
Looks like it.
M3 can take AIFF 48khz from page 1 initial specs?
X1 dun have a line out i think...
M3 can power the Havi effortlessly.
ThanksM3 can take AIFF 48khz from page 1 initial specs?
Anyone know if M3 supports gapless playback of FLAC files?
