FiiO M3 Pro-3.5 inch display | Full lossless format support pro-grade ES9218P DAC |smart Ingenic X1000E processor Fullscreen e-book reader | 10-digit display calculator lossless HD sound recorder | picture gallery
Jun 3, 2020 at 7:03 PM Post #47 of 53
First Impressions Post Time:
It's packaged very nicely, slipped my Micro SD in and it's currently doing a Media lib update. I have over 10k files (mostly flac) So it's taking a few minutes, if you have larger libraries set it to update and go do something else for a few minutes. Once it finally did i set the date and time on it. As for sound it is clear enough,though i want to clarify I am not a major audiophile, but i know it's not muffled, or too tinny. to me its fairly balanced. Shuffling all of my music and tapping (or swiping) for the next song is fairly snappy as well. It has crashed Once so far, during shuffling 16k songs. Album art doesnt have the same lag that the M3K has, though id suggest keeping any embedded album art under 1000x1000. Speaking of, if you have any cover.jpg in any folders, the Gallery will pick them up. Album art also seems to be more supported than the M3k and also the Rockbox port for it. If you have playlists premade it doesnt seem to support them, It cant find the files in the playlist, the M3K had this issue too and there's a rather annoying fix for it, too. Lock screen controls work snappier than when the screen is unlocked. I am going to stop here, but Keep in mind this is out of the box, with no updates. I'm gonna go and check to see if there are any updates for this device.
Jun 4, 2020 at 4:53 AM Post #48 of 53
Jun 8, 2020 at 11:52 AM Post #49 of 53
Hi,
Thanks for sharing your impression.
The M3PRO could support .m3u playlist. Does your playlist match the path?
And you could read this thread for making the playlist:
http://www.fiio.me/forum.php?mod=viewthread&tid=43891&highlight=playlist
Video help:
Best regards
These playlists only work if the drive is set to A: and even then, any playlist with considerable amount of music tends to freeze the player. I also can't shuffle my music either without it crashing and rebooting. I don't think this player is meant for larger libraries, at least not FLAC libraries.
Jun 9, 2020 at 4:36 AM Post #50 of 53
Hi,
Please try to update the firmware to latest version and format your card to FAT32 file system to check again?
Best regards
May 4, 2021 at 2:58 AM Post #53 of 53
