can someone explain the best method, with examples of products if possible, to connect this DAP to a headphone amp? i use schiit asgard 3, the DAP has 4.4 balanced and 3.5 coax outputs that are headphone sockets, as well as usb-c for data / power at the other end. i've ordered cheap usb-c and 3.5 (stereo?) to dual RCA outputs, as well as a slightly better 4.4 balanced to RCA so far. can't be sure of the coax options, or if usb-c is viable, or which is overall the best likely method.
fwiw, i have filo's recent FT1 pro which seems to have a balanced end with it. the asgard 3 doesn't have a balanced output i know of. what stumps me is if balanced to an amp that isn't providing a balanced output is actually carrying a better signal than the other options. i'd also like to know for any future possible change or upgrade of the amp or DAC (24 bit schiit modi, currently) to see if i would get any benefit from balanced outputs.
