[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
Ben86
- Jun 24, 2015
Did you try to use Tidal over UAPP?
After done that, the same happens
Empty the cache on the app and try again
Don't workDid you try to use Tidal over UAPP?
Thank you, but unfortunately don't work...Empty the cache on the app and try again
I returned to listening to the Utopia with the M17 and they sound better, it is not as good synergy as with the 1266 TC, but it is pleasant to listen to.
Try reinstalling the app, hopefully it helps.
After pressing "yes"
Don't work, I log out and log in in my phone and works perfectly, enter in tidal in the sp2000 and works perfectly, only in m17 don't, is not wifi problem either from m17 or my network because when I turn off the wifi in the m17 it says no network, and when is on says error in log in, this is very strange
Ben86
- Jun 24, 2015
Try to change connection from 2.4ghz to 5ghz if it is possible. Also try to connect via smartphone hotspot. You can also try M17 factory reset....Don't work, I log out and log in in my phone and works perfectly, enter in tidal in the sp2000 and works perfectly, only in m17 don't, is not wifi problem either from m17 or my network because when I turn off the wifi in the m17 it says no network, and when is on says error in log in, this is very strange
Ben86
- Jun 24, 2015
Maybe device or brain burn-in is starting to make differenceI returned to listening to the Utopia with the M17 and they sound better, it is not as good synergy as with the 1266 TC, but it is pleasant to listen to.
You should try connect it to mobile hotspot from your smartphone.Don't work, I log out and log in in my phone and works perfectly, enter in tidal in the sp2000 and works perfectly, only in m17 don't, is not wifi problem either from m17 or my network because when I turn off the wifi in the m17 it says no network, and when is on says error in log in, this is very strange
Not even after factory reset
Try to change the password over smartphone and then use it on M17.
Total: 10 (members: 0, guests: 10)
