[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
May 15, 2022 at 4:33 PM Post #3,856 of 5,692
When using the M17 vis its USB-C connection to go into an external DAC are there any manual adjustments to be done? Or is it a case of connect and forget?
Which USB-C socket does one use?
Thanks to all who chime in. 🍻
I have not received my M17 yet, but I have downloaded and read the manual entirely; per the manual (pages 4-5) both USB ports are capable of being used as transport to an external DAC. The actual detailed instructions on how to do it is described on pages 49-50.
May 15, 2022 at 4:42 PM Post #3,857 of 5,692
Thanks very much pythagore. In to the Fiio App I go to select the USB out. đź‘Ť
May 15, 2022 at 7:33 PM Post #3,858 of 5,692
Hmmm... seems that the Fiio App let's the M17 become the DAC. As in
... you feed thr M17 an external source and it uses its own DAC to decode and then play through the Fiio Music Player. I will read on...
May 16, 2022 at 1:02 PM Post #3,860 of 5,692
These silicone cases are pretty good but ÂŁ27 is blatent theft ! 20220516_180216.jpg
May 16, 2022 at 1:04 PM Post #3,861 of 5,692
My m17 beast has arrived today. It’s so good! I know it’s expensive but compared to other companies flagship it’s kind of a bargain. Really good sound plus enough power for power much anything. Also looks better in the flesh
Let's just hope we can afford the electricity in the UK to continue to run it 🤣
May 16, 2022 at 1:05 PM Post #3,862 of 5,692
May 16, 2022 at 1:06 PM Post #3,863 of 5,692
Hehe there is that! M17 solar panel kit?!
May 16, 2022 at 1:20 PM Post #3,866 of 5,692
It's ok, bit too loose for me and the bottom has a tendency to open up. Last thing I want is to pick it up and it slides out on to the floor
ohh ok, this is dangerous
May 16, 2022 at 1:56 PM Post #3,868 of 5,692
My M17 is in, I haven't setup or updated it yet, but I have just listened to it via the BAT mode for a while. coming from the FIIO M15, so I'll wait for a few days of burning in before listening to it carefully.
welcome to the m17 club my friend.
May 16, 2022 at 1:57 PM Post #3,869 of 5,692
Agreed, I'm not the biggest fan of the current included case.
