it is where you have to choose Cancel. If I choose ok I have the same thing, sound nearly muted and not clean at all.When pairing with my stationary DAC (dCS Bartoc) M15s and M17 recognize the dCs Bartok and ask to connect. However, the music is only played very, very quietly,
FiiO M15S Pocket Desktop-Level Player Discussion & Impressions Thread
- Thread starter FiiO
Dear friend,I use the regular YouTube app I have downloaded on the store (I tried on the website too). Connected to my phone (good wifi connection)
Output here is to an external DAC but is the same if I use a headphone.
I tried the 18.25.39 version YouTube but it seems they I failed to reproduce the same phenomenon. If you are convenient, please send a small video and the log files(support@fiio.com) to us for check.
Best regards
Dear friend,@FiiO
Hello,
I'm also having problems with the USB output on my M15 (same on the M17).
When paired with my mobile DAC (ifi micro idsd BL) everything works with the fiio app and the output volume is fixed and I control the volume on the DAC. When using a streaming app (Qobuz, Radio paradise) I have to set the volume to 120 in the M15s.
When pairing with my stationary DAC (dCS Bartoc) M15s and M17 recognize the dCs Bartok and ask to connect. However, the music is only played very, very quietly, the DAC displays incorrect sampling rates and freezes. The Dac has to be disconnected from the power supply, then it will work again with my other sources. Something is wrong with the USB out on M15s and M17.
Greetings
If you are convenient, please send the log files(support@fiio.com) to us for check.
Extract a LOG file
For special software issues, please extract a LOG file under the root directory, unzip and copy it to the homepage. And then send it to us for analysis.
Please go to " Settings ->About device" , and continually tap “Model number", until the prompt "Have save output log to built-in storage" appears.
Then please wait for about 20 seconds, and go to player's internal storage, then send the folder "fiio_log " to us and inform us the time of the problem for further analysis.
Best regards
I am happy with my FIIO M11 Plus Ltd + Astell & Kern PA10 class A sandwich connected via a balanced interconnect - it's great sound, big stage and holography.
Has anyone tried to connect FIIO M15s to A&K PA10 - what impressions, it's a good set and there is progress in it?
Has it already been fixed by FIIO in the new firmware or is there still a problem that FIIO M15 also have a crack in a fraction of a second at the beginning of the song, e.g. from Tidal, such a quiet crack? especially audible when successive tracks have different sampling?
The newest FIIO Control apk for Android smartphone - can control via BT - FIIO M15s? - would have been nice.
I tested, I installed FIIO Control on a smartphone but it does not see the DAP M11.
Currently, I use the FIIO M11 Plus ltd BT remote control - FIIO RM1 - it's very convenient,
you don't have to flick the screen to switch the next or previous track or change the volume.
It's an old model now is newer FIIO RM3 - has more buttons can be used with M15s?
Sybase
@madzic What is the workaround you are referring to? I would also like to use DC mode and USB DAC Mode together with my M1 Mac.Plugged to an USB-C plug with Thunderbolt protocol (windows laptops and last gen macbook m2), DC Mode works and the combination DC Mode/USB DAC Mode can work with the already stated workaround.
Yes, the new RM3 can work with M15S or any FiiO DAP based on Android . the RM3 has more buttons so it is more easy than RM1 , plus it has one customed buttons.
EdgeDC
Was there ever an RM2? Or is this just a simple case of FiiO strongly preferring odd numbers instead of even numbers?Yes, the new RM3 can work with M15S or any FiiO DAP based on Android . the RM3 has more buttons so it is more easy than RM1 , plus it has one customed buttons.
Sybase
@FiiO
I'm interested in the M15S and I hoping this can be my all-in-one solution, but I have some questions.
Could you provide some more noise floor specs at different levels of gain?
Your website lists <5.2μV (A weighting) for balanced headphone out on super high gain and ultra high gain, and <3.2μV for unbalanced headphone out.
What about low, medium, and high gain?
Can you confirm or deny that USB DAC mode and Desktop mode can be used at the same time?
Can you adjust the volume of the 4.4mm balanced line-out?
Not exactly your case but I can use desktop mode and sending my flacs to my DAC at the same time.
Sybase
Woah that this is very interesting. Good to know.
Yes, and this desktop mode makes the M15S an absolutely perfect tool to feed any DAC.
Thank you for your answer.Tak, nowy RM3 może współpracować z M15S lub interfejsem FiiO DAP zainstalowanym w systemie Android. RM3 ma więcej zalet, więc jest łatwiejszy niż RM1, a ponadto ma jeden niestandardowy przycisk.
Good to know that the RM3 is compatible with the M15 and can use all keys. It is a pity that the website does not have information about the compatibility of RM3 keys and with what devices. https://www.fiio.com/productinfo/1006385.html
Does FIIO Control app support FiiO M15s?
Maybe there is another application thanks to which I can remotely control the FIIO M15s from a smartphone - when connected to a stationary set in the room?
Dear friend,Thank you for your answer.
The FiiO Control app does not support M15s. Here is the list of the supported devices for FiiO Control.
You could try the FiiO Link function in FiiO Music APP if you would like to remote control the FiiO Music app in M15s.
FiiO Link Wifi function: https://www.fiio.com/newsinfo/825433.html
FiiO Link: Bluetooth function: https://www.fiio.com/newsinfo/825431.html
Best regards
