FiiO M15-FiiO releases the new firmware FW1.0.4 for M15
Jan 13, 2021 at 9:33 AM Post #18 of 24
Hello FiiO
The above 96kHz bug still remains even with this new Firmware.
Playing files >96kHz using more CPU power than "ALL to DSD" (All Players on the M15 are affected including the FiiO Player). I already reported this to the support (and it is confirmed).
Is there any timeline for a fix?
Best regards,
Marco
Jan 14, 2021 at 8:54 PM Post #19 of 24
Hello FiiO
Best regards,
Marco
Dear Marco,
Please send the log files and one of this music file to us(support@fiio.com) for check. If you are convenient, please send the app you used for test to us as well.
When the certain problem happens on the M15, please go to " Settings ->About device" , and continually tap“Model number", until the prompt "Have save output log to built-in storage" appears. Then please wait for about 20 seconds, and go to M15's internal storage, then send the log folder "fiio_log" to us for further analysis.
Best regards
Oct 22, 2023 at 9:12 PM Post #20 of 24
why doesn't fiio update the firmware of the dap itsself instead of upgrading just the fiio music player.
I love the m15 but the fact that they don't update the firmware to a newer android and see further performance improvements. it's the one thing that I feel is a big letdown with fiio.
Oct 22, 2023 at 10:29 PM Post #21 of 24
Quoting FiiO here from their official forum:
M11/M11Pro/M15 are all based on the same Samsung Exynos 7872 SoC which was announced in Q1 2018. Exynos 7872 latest supported Android version from Samsung is Android 7.0. So unless Samsung could provide the support of Android version update for this chip, or we could not update the Android version in those products.
It's not really up to them, at this point.
Can they secure an allotment of high end mobile CPU's? Keep it profitable and at a price consumers will pay? Just business.
Feb 22, 2024 at 2:57 PM Post #22 of 24
Updated at 2020-12-30
M15 FW1.0.4 firmware download: Click here
The following changes and improvements have been made to the FW1.0.4 compared to the FW1.0.3 on M15:
1. Added a new function of disabling the volume knob (can be set in Settings -> Audio or in the pull-down shortcuts menu;
Note: when the volume knob is disabled, turning the knob will not directly adjust the volume but trigger the volume slider on the touch screen. In this case, you can adjust the volume using the volume slider, or control it through FiiO Link. Also, you can trigger the volume slider when using FiiO Music by swiping up at the bottom-right area of the Now Playing menu);
2. Added full-screen album cover display and spectrum display (can be set in FiiO Music settings -> Theme -> Now playing menu);
Note: In the spectrum display mode, click the title or artist display area activate the time progress bar; switch to the lyric page and then return to the cover page to hide the bar.
3. Added sorting by artist under the Album category;
4. Added displaying the total number of tracks in the track list;
5. Added a new function of switching between album list display or track list display under the Artist/Genre category;
6. Added support for using any image file as custom album cover;
7. Added a shortcut for toggling the All to DSD function in the pull-down shortcuts menu;
8. Added file sorting in FiiO Link mode;
9. Added sliding on the bottom control bar to skip tracks in FiiO Link mode;
10. Miscellaneous bug fixed.
How to upgrade the M15:
The player supports online upgrade. If a new firmware is available and detected (with the player connected to Internet), you will find the update notification in the notification center. Then you can tap on it to enter the update menu for online upgrading.
If there's no update notification found, you can open the "Technical Support" app, enter the "Firmware Update" menu, then tap the "Check for updates" icon to check manually.
Also, the player can be upgraded locally using firmware package: Download the firmware file from FiiO website then copy the firmware package file to the internal memory or micro SD card; Open "Technical Support" app on the player, enter the "Firmware Update" menu, and select the firmware package file to upgrade.
USB DAC driver for Windows 7/8/10: click here
How to access the storage in computer: Click here
Updated at 2020-08-03
M15 FW1.0.3 firmware download: Click here
The following changes and improvements have been made to the FW1.0.3 compared to the FW1.0.2 on M15:
1. Added global MQA support, and improved the MQA playback;
Note: When scanning for tracks, the app will detect whether the tracks are MQA or not, which may slow down the scanning speed if you have MQA tracks in your library.
2. Added displaying sample rates on the status bar (you can enable it in Settings -> Display -> Display sample rates);
2.1 This function is only available when playing music locally, and it does not work for the USB DAC, Bluetooth, USB Audio modes;
2.2 When playing MQA tracks, the status bar will display the original sample rates of the MQA track instead of the playing sample rates after fully unfolding, as requested by the MQA licensor.
3. Added 'enter sleep with one click' function (you can find the 'enter sleep' icon on the home page and tap on it to have the player enter sleep mode);
Note that when this function is performed, the player will also close the apps running in the background and turn off the screen to enter sleep mode. After that it can only be woken up by pressing the physical button;
4. Added support for screen rotation (can be set in the pull-down menu or in Settings -> General. The screen will rotate upside down when this option is enabled);
5. Added Eye Care Mode (can be set in the pull-down menu or in Settings -> Display);
6. Added battery level and volume level display for USB DAC, AirPlay and Bluetooth receiving modes;
7. Added quick-charge indication and charging animation (displayed in the lockscreen when connected to charger);
8. Added a new function of hiding the un-scanned or empty folders in Folder view menu (can be set in FiiO Music -> Settings -> Scan for music. When enabled, only the titles of the scanned tracks will be displayed in Folder view menu);
9. Added 'File size limit for album art' function (can be set in FiiO Music -> Settings. And after selecting a limit, the album art image whose file size exceeds this limit will not be displayed);
10. Added album art display in Folder view menu;
11. Added two new options to the Multifunction button setting: Play/Pause, No function specified;
12. Fixed the issue where the input keyboard would be changed to the default keyboard after waking up the player with one click;
13. Fixed the issue where the DSD tracks could not be played in DLNA mode;
14. Fixed the issue where the Google account data could not be backuped;
15. Improved the Channel balance adjustment and increased the adjustment levels to 20 levels;
16. Miscellaneous improvements on performances.
Updated at 2020-03-27
M15 FW1.0.2 firmware download: Click here
The following changes and improvements have been made to the FW1.0.2 compared to the FW1.0.1 on M15:
1. Added Google Play framework(if you do not need it, you could unistall it from Settings->Apps->Google Play services);
2. Added FiiO Music widget(long press the homepage to pop up widget lists, and then choose FiiO Music to put it on the homepage);
3. Added grouping tracks by Album Artist category(You can select the Artist or Album Artist in the Settings->Artist List Display. This upgrade requires a database update, please scan for music again.);
4. Added displaying volume level numbers on the status bar(You can enable it in the Settings->Display->Volume display);
5. Added a new feature of scrolling displaying the currently played track while in a playlist;
6. Added a new feature of automatically pausing the playback after playing for 2 minutes without any headphones plugged in, so as to avoid triggering playback by mistakes;
7. Added global USB Audio output (from now on you can get USB Audio with no SRC for all third-party apps; currently only the PCM format is supported, the DSD format will be added in future update);
8. Fixed the issue where the Gapless playback would not work when playing DSD tracks;
9. Fixed the issue where the WiFi connection might drop when the screen is locked;
10. Fixed the issue where some buttons would still work when HOLD is set to ON;
11. Fixed the issue where a few types of tracks could not be played properly;
12. Fixed the issue where there might be noise when playing in Tidal with All to DSD set to ON;
13. Improved the sorting by Artist (now the articles 'the, a, an' at the beginning of the names will be ignored);
14. Improved the sorting of Japanese characters;
15. Improved the rule of HR audio quality classification (according to the JEITA standard);
Note:
If you have installed the FiiO Music standalone version before upgrading the firmware, there will be two FiiO Music icons on the home page after the upgrade. To restore it, you can go to Settings -> Apps -> FiiO Music, tap "DISABLE" and then "ENABLE".
fiio m15 or astell kern sr35 ? My headphones are the focal utopia 2022 and the sony mdr z1r
Feb 23, 2024 at 10:18 PM Post #23 of 24
Dear friend,
The M15 has stopped production now. And due to individual preferences, you could read the professional reviews and comparisons, as well as try out by yourself.
Best regards
