imz14u2nv
- Jul 15, 2005
Firstly, if the reason for having DSD512 is to because you want to have a rate more than the DAC internal oversampling rate, here you already have it with DSD256, because AK4499EQ does 128X oversampling rather than 256X:
https://www.akm.com/content/dam/doc...dio-dac/ak4499eq/ak4499eq-en-productbrief.pdf
Second, if they would use an older and slower SoC like many others did (A&K with SP2000 still uses the same SoC they used in SP1000) to support the DSD512, then you would probably be disappointed that they used an older SoC. And for what are you dissapointed? That you cannot use DSD512? And did you for once with M15 try the DSD512 through the USB and then play DSD256 on the player, hear any minuscule of a difference and then got dissapointed? Or just dissapointed of some numbers on the paper?
First let just start with the basics.
Yes, the original reason for wanting to play the DSD512 was simply to see if there was a noticeable difference/improvement over the lower quality rates, that’s it, Not sure why that would not be reasonable to any Half Way Intelligent Human. Isn’t this what we do in the Audiophile Hobby?, we buy whatever we can afford to try and get closer to perfection.
So, to answer your question, No, I have never tried to play the output from the M15 through anything, like most people who like to be really smart and assume you know everything, you have not taking into consideration that maybe, just maybe, there are people that don’t do that, I brought the FiiO X7 Mark Ⅱ and now FiiO M15 as standalone players to enjoy music.
I have only the following gear for enjoying music:
FiiO X7 Mark Ⅱ
FiiO M15
HiFiMan Ananda
Meze Empyrean
Jerry Harvey Audio Roxanne
Ultimate Ears UE-11 Pro
That is my gear, just things I can listen to without the need for that is non portable.
My only disappointment was that when I saw that the M15 was able to play DSD512 (This was during the original announcement), I remembered seeing the music from Native DSD "nativedsd.com 5 TRACKS IN DSD 512 (2019)” and thought I would purchase them to see how good it actually sounded, that was it, nothing more, nothing less.
I’m not sure why this would need to be a debate in a forum unless you are just completely bored with nothing better to do with your time.
