Glad to hear about that. Thanks for the feedback.
Best regards
Best regards
You'll have to ask Tidal for 8x unfold. Use uapp until then.
Some user told us that the Tidal APP could support 8X MQA after disabling "Loudness normalization" in Tidal app. Maybe you could have a try.
Best regards
If your having to go that high on the volume then you should try the high gain, if that still doesn’t give you enough try over ear mode, or Bose versa.I recently got my i4 and M15 and found the volume lacking on 3.5. Using just low gain and KMann's PEQ Toneboosters settings and UAPP, I found volume 110-115 where it was decent. But, with regards to those using Hugo 2 as far as power output for apples to apples comparison, what is the optimal setting?
As many have said i4's scale with more power, I was wondering if I should be setting everything to the max and using High Output Mode or high gain or both. Or, is that too much and risk damaging the i4's?
Edit* as far as I am aware Hugo2 doesn’t have any gain settings
Comparable output to Hugo 2 would be to have balanced output and over ear engaged.I see.
If so, would a comparable output to Hugo 2 be via balanced and low or high gain with high output or none at all? Pretty new to this voltage amp output thing.
Good day to all you guys!Tidal app x8 seems to work for me! I have loudness normalisation off.
