FiiO M15 Audio Player | Dual AK4499EQ | 7490 mAh Battery | 64 GB ROM | $1299.99
- Thread starter xenoVa
LightBlue77
why is it quoting a different user? have you edited like this?
FiiO I LOVE YOU!!!A firmware patch to enable Google Play store in M11/M11PRO/M15 based on the SoC used--Samsung 7872
Download link: http://fiio-file.fiio.net/Google_Play_Update.zip
How to update: Copy the firmware package file to the internal memory or micro SD card; Open "Technical Support" app on the M11/M11PRO/M15->enter the "Firmware Update" menu->select the firmware package file to upgrade.
Note: The Google Play partial library will prompt for updates after connecting to the Wifi for the first time. Restart it so that you could use it normally.
What can be done if receiving 'the device is not certified' in Google Play?
Currently, Google has closed the channel of GMS certification for Android 7.0 devices. So you will be prompted that the device is not certified. You can register your device by following the steps below:
(The deivce without certification could use Google Play normally still, but some apps with high security requirements could not be searched. )
1. Install the DeviceID.apk
2. Click it to get the 'Google Service Framework' and then copy it
3. Go to the following website and fill in the ID copied from step 2
https://www.google.com/android/uncertified/
If you have any questions or advices,please post in this thread or send an email to support@fiio.com
Best regards
But I'm still unable to install UAPP from Play store ("!not compatible with you device"), had to install some 5.4.1 version from google.
Read a few post above ?
Looks like we still need native hardware support. DSD is software converted to PCM and fed to the Android audio subsystem. The same thing also confirmed with Neutron player. Or am I doing something wrong here (there was an app for DX200/220 which enabled using the native hardware like a USB DAC):
I'm sure it will come now google play is official.
I did, but didn't get it about that extractor thing...Read a few post above ?
LightBlue77
install apk extractor on your smartphone or another device that already has uapp (the one with blue android robot in play store), open it and choose extract for uapp, then copy apk on your m15.
That also means that the previously mentioned DSD512 playback support which @edwardsean mentioned is actually not true, as I see also the Neutron player is doing PCM conversion for all DSD files.
- Install the UAPP on your mobile
- Search for a 'APK extractor' application and install it.
- Run the APK extractor and select UAPP. It will save UAPP APK file on your storage device
- Copy the extracted APK file to your M15 and run it.
install apk extractor on your smartphone or another device that already has uapp (the one with blue android robot in play store) open it and choose extract for uapp, then copy apk on you m15.
YOu guys rock!That also means that the previously mentioned DSD512 playback support which @edwardsean mentioned is actually not true, as I see also the Neutron player is doing PCM conversion for all DSD files.
Now all we need is MQA and the player is unbeatable.
I don't if I'm wrong bit I thought that the full support DSD512 etc is when using Fiio music mode, similar to mango on dx200/220. I'm sure I had the same issue with the Ibasso in regards to this. Obviously UAPP changes this so that it's possible in Android mode.
This would mean that like Ibasso it's nots untrue just not possible without using pure music mode or UAPP
