well canceled the fiesta the rectangle reappeared after 30 min of use false joy, god damn "/$%?&*
FiiO M15 Audio Player | Dual AK4499EQ | 7490 mAh Battery | 64 GB ROM | $1299.99
- Thread starter xenoVa
Dsnuts
- Jun 20, 2011
Does that rectangle dissapear when you have album art and UI displayed on the screen or do you notice it all the time?
A.L.W.A.Y.S
That sucks, wow!
I would love to hear the reason fiio will give me
orangecrescent
I am wondering if the rectangle is due to the heat from the underlying electronics? Or is it a deliberate feature to highlight the center portion of the image? Or just a bona fide defect of that batch of screen?
I don’t know but it’s a total disappointement, I can't imagine I'm the only one who's seen this problem... seriously I want a fiio explanation, find me a reason and don't tell me to do an update. @FiiO @JamesFiiO it's my second dap in 1 week
I'm assuming that the batch your 2 units are from may be part of a bad lot. Not seen any other similar type of issue. Doesn't really help you in the short term but may be a reasonable explanation for the issue. Might be worth getting a refund then buying from another retailer.
I am embarrassed to return my dap now that I have already done it to have another one,they will think i am crazy, it is fiio which should replace it for free or / and find a solution to my problem.I wrote a message to them directly to their support I hope he will answer me quickly before my trial period ends
what makes me the saddest is "Good God he plays well"
orangecrescent
I have that rectangle too. Just that "minor" things like these no longer affect me anymore (twenty years ago it might be a different story). But I totally agree that you have every right to be bothered by that thing. See if fiio can do anything. If not, maybe just return it and wait 3 months to try again to ensure getting a new batch or simply consider a different dap. Don't force yourself to accept it otherwise you are going to hate it every time you use it.
Well, let's see what fiio says about that rectangle first.
Personally, let them give me a valid reason and the why of this thing, I reread the specifications on the site and nowhere do I see or he mentions that I would have a rectangle on the screen. This is the kind of detail I don't want to have on TOTL... when i put 1500$ buck on the table for a dap i want a Spic and Span produtct without hardware problem
orangecrescent
LOL
I'll be curious on what they say too.
And I really paid particular attention the first time I turned it on and I had no rectangle at the start and I saw it appear afterwards, so the theory of circuits heating up is plausible.
Total: 6 (members: 0, guests: 6)
