FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
Jul 21, 2020 at 3:31 PM Post #1,352 of 1,931
Jul 21, 2020 at 3:32 PM Post #1,353 of 1,931
Thanks.. I was hoping it would - as I'm considering buying the PRO version.
Anyone else start with the M11 and upgrade to PRO? What did you find when you did?
Jul 21, 2020 at 7:00 PM Post #1,354 of 1,931
I auditioned the M11 and M11 pro side by side using Focal Elegia headphones on balanced. Music was Dianna Krall jazz. The M11 pro was significantly clearer, with better isloation arond the instruments, and deeper soundstage. Purchased the Pro and have been very happy. One man's opinion.
Jul 21, 2020 at 7:05 PM Post #1,355 of 1,931
Jul 21, 2020 at 7:30 PM Post #1,356 of 1,931
Will the clear silicone M11 case also fit the PRO version?
Can tell you next Monday when I come home from work but tbh the PU case is great. Silicone one i ordered as well just to see if it adds greater protection for lugging around when travelling.
Jul 21, 2020 at 10:10 PM Post #1,357 of 1,931
My video review about the M11 PRO is live now!! This is probably my longest video review, and it shows why for flagships I really need to write the review, it is just simpler to cover everything. This being said, the video review is really fun to watch, or at least I hope so, it has a lot of memes, jokes, sass, honesty, and even lots of pairings and comparisons. If you want to know more about M11 PRO, here's my full take!!
Jul 23, 2020 at 5:29 AM Post #1,360 of 1,931
Update note:
1. Added tracks sorting within playlists (now the playlists sorting, which is based playlist names, and tracks sorting within playlists are controlled independently);
2. Improved the MQA identification and playback, fixing the issue where a part of the MQA track would be missing when switching tracks, and also added MQA playback indication on the status bar;
3. Improved the issue where the folders loading would be slowed down when the "Hide un-scanned folders" option is enabled in Scanning settings;
4. Fixed Sony Hi-res application can't be played;
5. Miscellaneous improvements.
Jul 23, 2020 at 9:58 AM Post #1,362 of 1,931
What filters did you use on your M11 Pro?
I found that nearly all filters sound very, very equal. But i use slow roll of filter at the moment.
What filter did you use and why?
Jul 23, 2020 at 6:30 PM Post #1,363 of 1,931
Slow roll off as well as it sounds best to my ears. Tends to be what I land on with most DAPs.
Jul 26, 2020 at 12:23 AM Post #1,365 of 1,931
I'm using FH7 IEM's and when I use EQ and take about 4dB out of the 8 kHz band, I get a cracking sound on the musical notes. I.E. when there is no music, it's silent. Anyone else noticed this?
