I bought it from them and fit hardly first time after a week and some moving around is perfectly usable
FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
- Thread starter JamesFiiO
- Tags
- fiio fiio m11 pro
If FiiO supply a case with the standard M11, why can't they supply a new one for those customers who have paid extra for a premium product?
I've said on the FiiO forum, I won't buy any more DAPS from them if they don't include a case, and I've had most of their output to date. My X7ii that cost the same as the pro in the uk at £599, came with two.
Right, I see what you are saying, and I am sharing what I am reading and seeing with my own eyes - do you see that too? In your Status bar, 384k?
@FiiO - perhaps you can enlighten us as to what the 384k in the Status Bar is supposed to be indicating?
How does the 384k related to the full unfolding of 96k 24 bit files - as indicated by the UUAP streaming Tidal MQA files? Is it simply an indicator to differentiate full unfolding from 1x unfolding? Or is that the end PCM rate output of the unfolding?
Hi,
Thanks for your kind feedback. We have also reported that to the engineer for check.
Best regards
Thx1326
- May 16, 2012
Fiio Support - 2 questions:
1. Are there any plans to bring back the display with the working VU meters?
2. Any plans to be able to set the power button to be lit when the power is on?
Thanks.
Thanks.
peterinvan
I bought this case and it fits nicely. I went further and added four clear 10mm feet/bumpers to allow airflow for cooling.
https://www.amazon.ca/gp/product/B082QX6Y92/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Dear user,Fiio Support - 2 questions:
Thanks.
We will report to the product manager for assessing about that.
Best regards
ThomasHK
- Aug 12, 2013
Finally, mqa unfolding works in Tidal!
Is the sample rate indication in the status bar only a new feature from this beta release?
I'm on the latest official release and there's no sample rate indication in the status bar.
yes only in new betaIs the sample rate indication in the status bar only a new feature from this beta release?
garfieldso
- Aug 3, 2011
1. When connected to external dap, dsd files .dsf cannot play?
2. Also when connected to dap, the MQA file will send out as 44.1Khz, although I have set the MQA to on ?
(I am using official 1.02 firmware at the moment)
Thanks.
Thanks.
Fiio M11Pro its an exceptional Dap. My first dap to date. Bravo Fiio.
Thanks.
When connected to external dap? Are you using the M11PRO as USB DAC for the other player?
Best regards
garfieldso
- Aug 3, 2011
No, I am not using as DAC, it is like to be an storage and send out song files to external DAC. All the flac files ripped standardly in 44.1 kHz can play flawlessly without problem except the 2 kinds issue mentioned before.Dear user,
Best regards
Thanks
Thank you!Fiio M11Pro its an exceptional Dap. My first dap to date. Bravo Fiio.
Best regards
raykkho
- Apr 30, 2007
I have a request to fiio engineers
Please enter VU meters
Many owners are eagerly waiting for VU to be available on the M11 / pro
