emilsoft
- Dec 5, 2014
Dear friend,
The M11 Plus LTD will get a bit hot because of following factors:
1. Initially, check the "ALL to DSD" function is enabled or not. Because this function requires large amounts of computing resources. The CPU needs to be fully operational. Its power consumption will reach to the highest level and cause a large amount of heat. If in this case, switch off the "ALL to DSD" function.
2. Furthermore, the internal intelligent charging management circuit will also consume a lot of power in the process of charging electronic products. If the player is playing music at the same time. The heat will be more than normal. Usually, it is not recommended to use it while charging.
3. Additionally, the use of leather case and protective case will affect the heat dissipation of the M11 Plus LTD. And the temperature will be slightly higher.
4. Finally, the M11 Plus LTD uses two AK4497 chips that consume a lot of power to achieve high sound quality. It generates more heat than other chips when it works. Therefore, the M11 Plus LTD will also emit heat when it is working normally.
If you get that attention, you could wait some time until the temperature decreases. And if the attention appears too frequent, please contact support@fiio. com about that.
Best regards
Thanks for the tips.
I think the heat warning was because it was on a fast charger whilst playing music and inside the leather case. On normal charger it's much slower but doesn't have overheating issue. I also find the leather case hides a lot of the actual heat, the device might be very hot but the leather might feel luke warm.. so I've taken it out of the case for now and will look for a TPU style case with a cutout in the middle of the back similar to the M11 Pro one.
