Thanks for the feedback, the issue has been reported to engineerHello @FiiO
i wish to report an issue : on Fiio music app
when i choose Settings
set Language field as Italian on the "i" present on some fields for example USB output to see more info the Language is spanish not italian
it doesn't happen if for example i choose English or French , i see the added info in the corrispettive language setted
BR
[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
- Thread starter FiiO
jaxz
- Aug 27, 2014
What's the difference between M11 + and M11 + LTD ?
It is the same product.What's the difference between M11 + and M11 + LTD ?
rlw6534
At least for now. Technically there is no M11 Plus (non LTD) as the LTD refers to the now discontinued AK4497 DAC. I guess we will have to wait and see what they call the ESS 9068AS DAC version.
Mine gets pretty warm when streaming lossless Apple music.Most probably it does, but my M11 Plus barely gets warm anyway, even after listening to DSD128 for about an hour.
I've read here before the device can get pretty hot, but in what situation?
mRaaghava
- Sep 29, 2016
That’s the case with all DAP manufacturers. FiiO, iBasso are a lot better now than before when they were using Rockchip processors. But, a phone+dacamp will always be better but not portable.M11+ is okay,but I wouldn't save money for the ESS 9068AS version,get a mid range phone and dongle or a portable dac/amp to go with it, you'll make out better, Software game over at Fiio is not up to par for the prices you're paying and it's not just Fiio.
It is the same product.It is the same product.
https://fiio.com/m11plusltd
FiiO M11 Plus LTD or FiiO M11 Plus or FiiO M11+
Again it is the same product.What's the difference between M11 + and M11 + LTD ?
FiiO M11 Plus LTD or FiiO M11 Plus or FiiO M11+ or FiiO M11+ LTD
The new version is supposed to be called M11+s or something like that.At least for now. Technically there is no M11 Plus (non LTD) as the LTD refers to the now discontinued AK4497 DAC. I guess we will have to wait and see what they call the ESS 9068AS DAC version.
jaxz
- Aug 27, 2014
Thanks Ichos.
Do you turn off the player when you press the shutdown button? Does it just reboot for me. This is right?
Audio Addict
- Aug 5, 2001
When I press the off button on the top left it brings up 2 buttons on the screen (1) Reboot (2) Shutdown. Press one of this moves that button to the center and then you have to push the button again to reboot or shutdown.Do you turn off the player when you press the shutdown button? Does it just reboot for me? This is right?
Power/Lockscreen:
- long press it for about 2 seconds when the device is off to turn it on
- long press it when the device is on to pop up the menu of reboot/shutdown, then tap one of the pop up menu to reboot or shutdown
- short press it when the device is on to turn off/wake up the screen
- long press it for about 10 seconds to reset the device
i click (shutdown) and it off and turns on
Understood! These are Russian localization errors! Reboot - this is Shutdown! Shutdown - this is Reboot)))
Total: 16 (members: 0, guests: 16)
