[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
Jan 23, 2023 at 12:44 PM Post #2,536 of 3,143
Yes :) But "FiiO M11 Plus" have DSD256 support and "FiiO M11 Plus II" seems to support DSD512
Torben
FiiO's marketing is confusing. On the official M11 Plus ESS page it says the ESS9068AS supports DSD512 and 768 kHz (note the asterisk). But the actual specs for the DAP are DSD256 and 384 kHz. I think we are all pretty sure that the M11 Plus II you see on the one French site is actually the M11 Plus ESS.
Also see this:
https://www.head-fi.org/threads/fii...ted-at-2022-12-28.956910/page-9#post-16372048
Jan 23, 2023 at 12:52 PM Post #2,537 of 3,143
THX :)
Anybody using it with Roon? It is now Roon Ready - if it works well with Roon, I would buy the M11 Plus
THX
Torben
Jan 23, 2023 at 1:07 PM Post #2,538 of 3,143
[Deleting Post....I quoted FiiO's site which is apparently wrong]
Jan 23, 2023 at 1:12 PM Post #2,539 of 3,143
Jan 23, 2023 at 1:12 PM Post #2,540 of 3,143
THX :)
THX
Torben
Yes, I use the Roon Ready feature with my M11 Plus ESS. It works fantastic!
Edit: Roon ARC still needs some work, as it is not bit-perfect currently. But it works outside of the Roon Ready endpoint.
Jan 23, 2023 at 2:03 PM Post #2,541 of 3,143
THX :)
THX
Torben
It’s all I use it for. Perfect RoonReady device, as others say ARC is still limited to standard Roon android app limitations but that’s being worked on.
Jan 23, 2023 at 5:09 PM Post #2,543 of 3,143
FIIO M11 Plus LTD is/will be able to play TIDAL Dolby Atmos and Sony 360 Reality tracks in the future?
Is this a hardware limitation of FIIO M11... - or a license one like in Roon?
On the M11 Plus, you can play Sony 360 Reality tracks but not Atmos (from Tidal). Atmos requires a certified/licensed device like Apple iPhone/iPad or a few high-end Android phones. I am not aware of any DAP that natively supports Atmos. This also true for Apple Music.
Oddly, Amazon Music does play Dolby Atmos on the M11 Plus. I can only assume that Amazon has licensed for the app, rather than the hardware.
Jan 24, 2023 at 5:27 AM Post #2,544 of 3,143
I don’t have any experience with Android, but it seems to me that the SW version on M11 Plus is from 2019 (version 10).
So it will probably soon reach end of life (support). Is It this going to be a problem?
THX :wink:
Jan 24, 2023 at 8:54 AM Post #2,545 of 3,143
Has anyone here had issues with the playback on the M11 plus stuttering/slowing? Often when I switch to a different music app I find that playback slows down (to approx half speed) and the audio cuts in and out rapidly. When this happens it usually affects all apps and the only solution seems to be to close all open apps and then start again. The apps in question are PowerAmp, PowerAmp EQ, Spotify, Qobuz. Haven't encountered this issue on any other Android device. It's really impacting usability, which is unfortunate because I love everything else about it.
Jan 24, 2023 at 9:36 AM Post #2,546 of 3,143
I don't think this is unique to the M11 Plus. Basically when you have multiple apps trying to control audio, especially with SRC bypass, things can become conflicting. I have seen this on other DAPs as well. Bottom line is it's best to use one app at a time and close others.
Jan 24, 2023 at 1:39 PM Post #2,547 of 3,143
Good to know! I don't have this issue on the M11S (bought both to audition, planning on returning one) so I assumed it was something specific to the M11 Plus. Sounds like it might be fair to say it's a general issue that is highly device specific?
Jan 24, 2023 at 2:28 PM Post #2,548 of 3,143
THX :wink:
That's a very good question.
FIIO M11 .... the series will grow old with Android 10 and die with 10 from 2019?
Will it be possible to update to a newer version of Android ?
Jan 24, 2023 at 2:39 PM Post #2,549 of 3,143
They could upgrade it to Android 11 or 12 as other DAP's with the Snapdragon 660 have come out with higher android versions. The question is will Fiio do it, and what benefits will it bring.
New players will eventually start coming with Android 12 or 13, as we see new chipset being used, reckon most DAP's will move to the Snapdragon 730 or 835 in the next 12 to 18 months
Jan 24, 2023 at 3:20 PM Post #2,550 of 3,143
Exactly, some of the apps even detect the install of potentially conflicting apps (Flat, Power Amp, Wavelet) and instruct you to uninstall them to avoid playback issues.
