[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
Jan 19, 2023 at 8:19 PM Post #2,521 of 3,143
Can anyone check if the android accessibility setting for mono audio is in the settings options?
It doesn't appear to be. The only audio-related accessibility setting is "Caption Preferences" in the "Audio & on-screen text" section. Sorry.
Jan 20, 2023 at 3:23 AM Post #2,522 of 3,143
OTA update just came online now as I was watching it to try and install the apk.
Jan 20, 2023 at 8:28 AM Post #2,523 of 3,143
For the M11 Plus II:
Wait some days (the french will ship them next week) and you'll (perhaps) see it also in the Fiio shop.
The current M11 Plus is current in discount and for me (the new one seems to have the same hardware, but can handle DSD512 for plus 100 bucks) this is s great deal.
Hi, anyone can make it clear?
Is M11+ LTD and M11+ is a different DAP than M11+ ii? Because I'm about to buy M11+ , and I don't want to miss something for my next buy.
Thank you :)
Jan 20, 2023 at 9:47 AM Post #2,524 of 3,143
Thank you :)
Current FiiO line is - M11S , M11 Plus ESS and M17.
M11 Plus LTD with the AKM DAC chips is discontinued.
Jan 20, 2023 at 3:53 PM Post #2,527 of 3,143
Just supporting what others have said.
I have a Fiio M11 Plus LTD and use Apple Music streaming with it nearly every day.
It works flawlessly and for my use case it works equally as well as Apple Music from an iPhone X, iPad Mini 6 or an older 2014 MacBook.
Are you able to download Apple Music files to the micro SD card’s storage?
Jan 22, 2023 at 2:45 PM Post #2,531 of 3,143
Does anyone know if the Official Fiio LTD case with the metal vent will fit the ESS Plus, is there any difference in dimensions? @FiiO ?
I have one and it fits perfectly.
Jan 23, 2023 at 3:44 AM Post #2,532 of 3,143
Mine works fine together. ESS and LTD share the same dimensions I believe.
Jan 23, 2023 at 12:28 PM Post #2,534 of 3,143
