Mathieulh
The only way a higher resolution sample would sound better is if it was already mastered at an equivalent (or higher) resolution to begin with (as the more you downsample, the less information you retain), that said the quality of a master is much more of a determining factor in regards to the quality of a sample than its bit and sample rates (unless it's really low and/or compressed), if you find redbook audio (16bit@44.1kHz) sounding better when upsampled (when in fact it would sound the same or (in most cases) worse), there is a name for it, it's called the placebo effect, it does wonders.Do you feel there’s any real advantage to high-res music using daps like the M11 then? The reason I ask is that I have many Redbook rips that sound better in many ways to their high-res equivalents. In fact I contend that the mastering of the original recording - not the file format or upsampling or downsampling - makes by far the biggest difference when it comes to perceived quality. Heck most people still get by with lossy files (shock horror!).
