The hiss is coming out of the right channel and it is clearly heard from all outputs (ballanced/ unballanced). It is there when not charging and regardless of the set gain value. It is also heard using various iems. Seems like a device issue.
My problem is : WHY DOES FIIO NOT RESPONDING?
For my part I've been trying to contact Fiio about a hiss issue my M11 developed out of the blue. No response from them after multiple e-mails. It is really frustrating.
I'm trying to use a Fiio M6 with a Chord Mojo to play DSD64 files via the DoP function, using a usb c to micro b cable, but not the Fiio Cable in particular, and I'm getting a lot of buffering type dropouts. When the music is playing it sounds excellent. Anyone know why I'm getting the buffering droupouts? Thanks for any help.
RE: M11 Battery Life w/ Build 1.0.9 / ota-2020041802
Hello.
I installed the above beta FW for the M11 a week or so ago. It seems to me that the battery drains more quickly with this version. This is strictly my anecdotal observation over various listening sessions, nothing scientific. I haven't changed any settings in the FiiO music app or the player itself. My listening habits are the same: FLAC music files, WiFi & BlueTooth off/ no streaming/ Google PlayStore uninstalled/screen brightness to about 15%/ screen timeout=1 min.)
Just wondering if anyone else has noticed any change in battery performance? (It could very well be my imagination...and I realize it's beta FW and that I can revert to the older official version...)
Also, is there a preferred time to charge the DAP: at what battery % is the best to maintain the overall life of the battery?
Thanks!
Hello.
Thanks!
Thanks, corgifall.
I strictly use the M11 with the FiiO Music app to listen to music. After I updated to this FW, I uninstalled Google PlayStore, not seeing a need for it. And although I can remove Google Play Services, after a reboot it reappears, so that must be an essential component of the DAP.
Are there other permissions that should be allowed?
[As an example: I've been listening to music (44.1kHz/16bit FLACs) just now for about 50 minutes and the battery has gone from fully charged to 91%. No screen use other than initial start up.]
Also- Earphones: Etymotic Research ER4SR Phone input: 3.5mm Gain: Low Volume average: @70 (for this particular album) EQ: None
If I remember correctly, google services was the other big one that needed to have all permissions allowed. I know there was an issue with play store and I'm pretty sure the google services sucking up battery because of the denied permissions. I use poweramp and upscale to the max and post permission issue fix I can get around 7-9 hours via balanced before the m11 starts getting angry at me over the battery.
