[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
RikudouGoku
Member of the Trade: RikuBuds
Is there no other player that has as good Sound quality as Neutron but with a better UI? I can not stand it, I want to use Poweramp love that UI but Neutron is clearly better in sound quality.
Jujoe
Maybe try Hiby app
Hope it helps
Juj
RikudouGoku
Is there a guide on how to install/buy neutron and which apk it is for m11?
RikudouGoku
Am I the only one that can not add an account in the settings? Running version 1.0.5
steamboiled
I don't think there is but it's pretty simple.Is there a guide on how to install/buy neutron and which apk it is for m11?
1. Buy directly from their site
2. Wait for email
3. Use link in the email to download the app
4. Download APKPure from the Fiio app store
5. Move the Neutron app to any of your folders inside Fiio?? I moved mine to downloads
6. Install Neutron thru APKPure
7. Use registered mail to activate
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
I found out the Samsung CPU is neon campatable so I installed the latest neon version. My friend naypram says the arm 64 version is correct- so I guess they both work- idk what the differences are, just the site said neon will be faster if it supports it. You buy if from their site directly and you have to put your email pop or imap into it to validate it. More info is a couple of pages or 4 or 5 back.
RikudouGoku
Do I need to disable my 2 step authenticator? I have activated POP and also gotten the recipe for the purchase. But it is still Yellow
EDIT: Ok disabled it and Lesser secure apps and it worked. Can I reactivate both of them now?
EDIT 2: activated both and still works.
M11 does not have Google services, that's why you are unable to add your account here due to this is a part of Google Services functionality. Strange that Fiio's programmers doesn't remove this from settings, maybe this is not available in Android's API.
Ulrich B.
Yesterday I removed mine from my bag and it was extremely hot and showing an alert saying it was too hot and to take off of charge. It wasn't on charge so I can only assume Fiio app had been playing continuosly and the unit overheated in the confined space of my bag. As a result I have now disabled the hardware buttons when the screen is off.
Hello, I can confirm that. My M11 had also been very warm. Had probably just turned himself in. But I haven't had an error message yet. The hiby music app was put on pause, but active in the background. What I also noticed, I use the M11 with my headphones, connected over 3.5 mmm the M11 becomes quite warm when playing online music. What could be the reason for this? On the amplifiers? Someone an idea. Thank you
Jujoe
Maybe the Wifi causing the heat, I find this happens to my phone when I stream.
Juj
At 3.5, the device heats up much more than 2.5
RikudouGoku
Do you guys use a Case other than the one that came with the m11?
Like these for example.
https://www.aliexpress.com/item/330...chweb0_0,searchweb201602_1,searchweb201603_60
Any recommendations?
Mine had heated up without anything connected at all. I don't think the TPU case can help with cooling either.At 3.5, the device heats up much more than 2.5
abitdeef
- Oct 30, 2003
Were you streaming? Because mine never gets hot. Not even warm really. I'm using high gain and balanced out.
Total: 8 (members: 0, guests: 8)
