Thank you very much for your advice. Should you be able to adjust the volume quickly in 60-step volume setting?I see. Too bad then. I always have issues with the volume adjustment with either mode A or B. In mode A, especially on 120-step volume setting, I have to press a lot of times to change volume, especially when changing IEMs or headphones. In mode B, I will have difficulty fine-tuning the volume settings because I have to long-press to adjust volume.
Also, to respond to your assumption that "the frequency of continuous volume adjustment is not much", I would say that if the user is only using one IEM/headphone at all time then this will be true. However, if the user has a number of IEMs/headphones and frequently change them around, drastically changing volume would be a very frequent operation. Also, some albums might be louder than others, so sometimes we need to change the volume quite a lot.
A few friends who have tried my KA5 complained about the same thing. Also, a lot of them are confused why the screen is always off when the volume is changed or the track changed (they often want to confirm the volume and sampling rate when the track changes).
I wish KA5 would behave much like my other dongles with screen (L&P W2 and Cayin RU6). Well, still a very good sound quality though!
Because a lot of people don't like to light up the screen when you press a button.
For example, phones don't usually light up when volume is adjusted.
