[FiiO KA17] Mini desktop-class amp, flagship dongle is officially released!
Jan 26, 2024 at 2:00 PM Post #76 of 1,219
Sounds like your in the wrong thread.
Jan 26, 2024 at 8:51 PM Post #80 of 1,219
The definition of 'most' powerful' can change a bit if we consider what smartphone we are using. iPhone for example is notorious for limiting its Lightning port's power supply so you need to get the right Lightning cable with the right MFi chip inside to get more power than typically allowed. Even different Android smartphones can vary by a lot. Samsung tends to be more limiting than most Chinese brands, while I like my Sony Xperia because Sony doesn't limit its power supply to any USB dongle. Of course, once we have the option of adding another Type-C power input from the side, it kinda doesn't matter anymore, more or less.
Jan 26, 2024 at 9:24 PM Post #81 of 1,219
The terms powerful can also depends on the sound transmission itself. For example, using both the RU7 and DC04 Pro, both 4.4 port, to drive my Shuoer S12, both dongle can only reach the same max volume of around 90db
Jan 26, 2024 at 11:16 PM Post #82 of 1,219
Here are some number for those who like to see some actual measurements of power-draw / output power. It is a bit tedious so I only measured the 3.5mm single-ended output, 47ohm dummy load with matched output to 0.095V (or otherwise vol 30/60 in normal mode and 27/30 in desktop mode). Note that my Sony Xperia, as mentioned previously, doesn't limit its Type-C power so it can, without external power, power the KA17's desktop mode. This is why you don't see any major difference between the results, with or without external power (which is a USB wall adapter that supports PD / QC / various power profiles).
Without External Power
SE: 5.18V 0.21A = 1.1W (Vol30)
Output: 0.095V 12.7mA = 1.21mW
SE(D): 5.18V 0.30A = 1.5W (Vol27)
Output: 0.095V 12.9mA = 1.23mW
*The first line is the power draw, and the second line is the 3.5mm output power. The next two lines are the same but in desktop mode.
With External Power
SE: 5.19V 0.03A = 0.16W | 4.95V 0.18A = 0.89W (Vol30)
SE(D): 5.19V 0.03A = 0.16W | 4.94V 0.28A = 1.38W (Vol27)
*The first line is the smartphone's power draw + the external USB power draw, and the second line is the 3.5mm output power. The next two lines are the same but in desktop mode.
As you can see, there is a small difference between normal vs. desktop mode. It might not be as big as one might think but my guess is because my Sony Xperia just doesn't care much about limiting power so KA17 is fairly well-powered either way, thus the difference isn't as noticeable. But there is however a noticeable listening difference for me personally, desktop mode provides just a little sharper image, tightness, and control even when volume matched.
Jan 26, 2024 at 11:37 PM Post #83 of 1,219
SE: 5.18V 0.21mA = 1.1W (Vol30)
SE(D): 5.18V 0.30mA = 1.5w (Vol27)
With External Power
SE: 5.19V 0.03mA = 0.16W | 4.95V 0.18mA = 0.89W (Vol30)
SE(D): 5.19V 0.30mA = 0.16W | 4.94W 0.28mA = 1.38W (Vol27)
There seems to be some confusion with your units when you write mA but it is actually A (e.g. about 0.28 A draw from the external power as your usb-meter in the picture shows and not 0.28mA) otherwise the measurements do not make sense. Also the output power is not fitting. Additionally a typo with the numbers creeped in at
assuming that it is also 0.03 A (!) so that the indicated power is correct, it matches my measurements where in external power mode there us practically no draw from the OTG host and almost all power comes from the external supply if that delivers sufficient power. The remaining small difference (in my case the draw from the host was below 0.01A ) seems to depend on the host device or on the external power supply (yours is below 5V…?).
Jan 27, 2024 at 1:23 AM Post #84 of 1,219
i wish I waited for the ka17. Ka13 is cool but options and a display would have been nicer.
Jan 27, 2024 at 4:10 AM Post #85 of 1,219
You are correct, some of the mA should be A. I rushed to post on the morning before I went to work so I copied and pasted all the same unit (*my original note doesn't have unit) without thinking straight. The other are just typo. Will correct soon.
Jan 27, 2024 at 11:06 PM Post #86 of 1,219
With External Power
210mA current draw seems pretty high for a usb dongle! @twister6 measured 150mA only for DC-elite (albeit DC-elite has lower output and the measuring condition not clear). i measured my own L&P W2 before (which has a reputation of being power hungry) only needs 120mA. i was thinking to buy KA17 but now probably will wait and see more feedback on the power consumption before making decision . . .
Jan 28, 2024 at 1:59 AM Post #87 of 1,219
210mA current draw seems pretty high for a usb dongle! ...
It is very high for an USB dongle, but it is also kinda source dependent. Hence the reason why I mentioned that my Sony Xperia doesn't limit power draw and thus you should see 210mA as more of a worst-case scenario. For example, Using Shanling M1s as the source, the average power draw for normal mode is more or less around 5.1V 0.18A = 0.9W or so. As a comparison, DC-Elite will be around 0.8W under the same testing condition, so KA17 isn't exactly the best choice if you have no intention of using an external power source or if power saving is high on your priority list.
Jan 28, 2024 at 5:48 AM Post #88 of 1,219
I have a Samsung A52. I'm assuming it won't work in dc mode without an external power source? I would really apreciate If someone with a Samsung phone can confirm If DC mode works or not.
