Eduardo75890
Possible support of MQA unfolding? My current Dac is K5 Pro
Dual ESS versions hasn't started yet.
But there are definitely functional differences,Probably cheaper in price.
I can't tell you exactly now because there are many variable things.
HiHi,
Will the K9PRO ES9038PRO Version be available in August?
Also, does the K9PRO have CPLD or FPGA processing?
Hi
Maybe ES9068*2 version will be available in August.
There is no FPGA, the K9 Pro uses Xmos+MSP432.
The K9 Pro needs to support decoding optical/coaxial inputs, which necessitates the use of XMOS's own Crystal Oscillators. So there is no real point in plugging in an external FPGA。
The method of sale has not yet been determined. I think staying tuned, users who really want it should be able to buy itThanks for the reply.
I see, That’s fantastic!
Will the few "AKM K9PRO" be sold by lottery?
HiSince there will be a lower model with a ESS Dac will it also support MQA? or the AKM version of the K9 Pro. I am quite new to MQA I currently two Dac one is the Fiio K5 Pro and the other is a MQA Decoder and Render DAC but I wasn't sure what is the different of the two since the K9 Pro will support MQA Render.
Sounds goodHi
K9 Pro and lower model with double ESS Dac will also support MQA![]()
Hello Everyone
I'm Willson, Product Manager of FiiO, and I'm here to introduce you to a new product:
FiiO K9 Pro Hi-Fi DeskDop DAC&Bluetooth&Amplifier:
SPEC:
1,Linear power supply, supports 115V/230V power supply.
2, AK4499 DAC,4.4mm Balance Output.
3, Support MQA
4, Customised THAAA AMP
5,USB DAC support up to 768kHz/32b decoding (DSD512 support)
6,Optical/Coaxial decoding supports up to 96k/192k sample rates respectively (DOP64 supported)
7,Bluetooth with the new QCC51xx series, support LDAC/aptX adaptive/AAC/SBC and other coding formats, support BLE control
8,Hi-END class parameters and configuration
Input Interface:
1,Digital inputs: BT/Coaxial/Optical/USB in
2,Analog input: 4.4mm/Line in/
Output Interface:
1,Line output
2,Balanced out XLR*2
3,XLR4 output
4,6.35mm/4.4mm output
Other:
1,Multi-state selection and indication
2,APP Control
3,Adjustable volume knob
4,The price will remain the same as usual and will always be a pleasant surprise for everyone.
5,Limited sales expected in April
Note:
1,Because of the AKM fire, the number of AK4499 chips is limited, so the number of K9Pros is also limited
2,A lower priced dual DAC version of the ES90xx will be available around August 2021
More information will be added gradually, if you are interested please discuss with us below, thanks.
So a 2x ES90xx will be cheaper than a 1x AK4499?Hello Everyone
SPEC:
3, Support MQA
Input Interface:
Output Interface:
1,Line output
3,XLR4 output
Other:
2,APP Control
Note:
Hello Friend, for your questions:Will the
And does it have duel THX amp or only one?
And will it have internasjonal shipping?
The method of sale has not yet been determined. I think staying tuned, users who really want it should be able to buy it![]()
