AdWiser
- Jan 23, 2004
3.5mm to 2.5mm are not that large. It could be true for XLR to 3.5/2.5mm or even 6.3mm to 2.5mm. But 3.5mm to 2.5mm not that big.
Even if it is big deal as you say, why not use adapter with 2, 3inch wire?
Remember K7 is a DESKTOP budget amp, not a flagship, megabuck amp or PORTABLE amp to provide all the connectors in the world. Most of the desktop amps (even megabuck amps like HeadAmp GSX-mini) doesn't have ports used for portable earbuds,earphones like 2.5, 3.5trrs.
Dear friend, please excuse my vague post. Monstruosity comes not from the size but rather the incorrect wiring. As much as I understand from what I red on above mentioned topics, there are fairly two correctly wired balanced jacks, intended for audio use: the 4.4mm and the 2.5mm. What some sell over the internet, marketed as ”balanced 3.5mm” is actually the 3.5mm jack with microphone connection, intended for mobile phone use. You can seriously damage your (expensive) balanced equipment with those. The same discution goes for the simple 3.5mm to balanced 2.5 or 4.4mm adapters, the same issue: bad wiring.
